Washing Machines Logo
c
catalina Posted on Jan 13, 2017
How many cu.ft.standard frigidaire washer.FWT445GE
5 Related Answers
Anonymous
  • 1294 Answers
  • Posted on Jan 12, 2008
SOURCE: Frigidaire FWT445GE will not spin
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Anonymous
  • 1489 Answers
  • Posted on May 12, 2009
SOURCE: What is the capacity (cu ft) of Kenmore washer
3.2 cubic feet
Anonymous
  • 7 Answers
  • Posted on May 27, 2009
SOURCE: What is Cubic Ft Capacity of Washer?
It's in the model number, and it's 4.4 cft. Which is one of the largest capacity washers available.
Anonymous
  • 10865 Answers
  • Posted on Jul 28, 2009
SOURCE: What cu. ft. size is my Whirlpool top loading
hi there. the best way to determine this is to measure the inside length, height and width and you will get cubic feet. Just be sure to convert each measure to feet. For instance 2 feet 4 inches = 2.33 feet.
Anonymous
  • 1998 Answers
  • Posted on Sep 02, 2010
SOURCE: My whirlpool cabrio he 4.5
Error Code - Ld Problem - Long Drain Solution - When the machine consumes 5 minutes or more to drain out water to where the operating pressure switch resets
How many cubic ft. in a 2001 Frigidaire Galley model #FWT647GHS washing machine
Hello friend, that's a great question!
I understand you would like to know the cubic footage of your Frigidaire washer. Based off the model number you have provided your washer appears to be a 4.4 cubic feet washer. I hope this information is helpful. -Matt
READ FRIGIDAIRE ERROR CODES
Hello Rob Olsen, I appreciate your inquiry!
I understand that you would like to have information upon reading error codes for your Frigidaire laundry center. I was able to locate a manual that has information regarding error codes for your laundry center. I hope this information is helpful to some degree. -Matt
Frigidaire Manual Search Results
Can an frigidaire X091307954 dryer be stacked on a Amana NFW7200TW 3.5 Cu. Ft. Front Load Washer?
this is possible, youll need a kit that sets on top of the washer,check back where you bought the washer and dryer, they make a washer and dryer combo thats one peice, they are smaller however
What is the capacity of this washer
Hello Diane Swartz - If your model number to your washer is GLTF2940ES, then the capacity of the unit is 3.5 Cu. Ft. However, if that is not the correct model number, may you please provide me the correct one?
2helpful
What is the size of this model? how many cu. ft?
This category includes standard-size top- and front-loading clothes ... Frigidaire. GLWS1649A. 449 $45. T. 85. 1.57. Frigidaire. GLWS1749A. 543 $54. F. 75. 1.26. GE. WCXH208A.
3.2 cu.ft
Top Frigidaire Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
