Washing Machines Logo
s
sarwar Posted on Jan 14, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want to know how can i cleare the erro f21 about siemens washing mechine.
Darran Hatten
Level 2:
  • Expert 236 Answers
  • Posted on Jan 14, 2017
Darran Hatten
Expert
Level 2:
Answers
236
Questions
0
Helped
129240
Points
792
Error f21 happens when the machine does not drain in an appropriate time. This can be caused by a blockage in the drain or a faulty pump. There is a previous post in relation to resetting this error. have siemens washing machine that says f21 what does that mean
What is an F21 error means in Siemens extraklasse WM14E391 washing machine?
its a motor tachometer fault, basically the tacho on the motor (you cant get it as a spare part it comes with the motor) is faulty or the control board is faulty and the machine is unable to detect the speed of the motor, the motor may work but if the board cant detect it moving you will get this fault, fun thing about this kind of fault is theres no easy way to determine whether its the board or the tacho
Siemens washing machine display F21 flashing. Fault is not resetting after power off.vario perfect iq 300.
Try this, unplug it and press and hold down the power button for 10 seconds and then plug it back in and see if the error code has cleared.
1helpful
1helpful
2answers
I have a siemens washing machine that says f21 what does that mean
Many thanks. For F21 fault everyone was talking about the drain valve but found one answer related to power supply n board this helped. Resetting by turning program switch to 12 o clock then turn to 6 o click then keep spin button pressed n move knob to 7 o clock position. Then release spin n move knob to 12 o clock. This way F21 got resetted.
The drum have stopped going around. Is it worth repairing?
washing mechine wont spin or drum stopped going around .siemans xli1240
7helpful
He2 plus front load washer keeps showing F21 error code. I cleared the drain pump filter. Still displaying F21 how do i check to see if i need a new pump
If you found a blockage in the pump screen restricting the drainage and it now drains fine but F21 is still there,the error code can be cleared by pushing the PAUSE/CANCEL 2 times within 2 seconds.
If after clearing the error code if it returns on the next wash cycle the pump will need to be replaced.
I hope this has helped you resolve your washer troubles,
Gene
3helpful
2answers
Siemens washer dryer model WD12D520GB, what is error code 17?
i think f17 is the code for low water pressure, check the water supply to the machine is turned on and the hose is not blocked or kinked or pinched
F 21 error code
F21 Long drain Possible cause: Clogged filter, clogged/failed pump. Get the bottom panels screws out and remove it. Tech sheet with erro codes and diagnostics are behind the white motor control box to the left.17faa85.jpg379e38c.jpgccf409c.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Can not clear F21 code even after doing all steps in book
"F21" is a long drain error code. I have a link that you may try to see if there may be some additional things you haven't tried yet:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
Try unplugging the washer for at least 30 minutes (if you haven't tried that already). This will reset the Central Control Unit (CCU). This is the main "brain" of your washer. Sometimes this is all that is required to correct momentary glitches. If the error code reappears, check your drain pump for obstructions. This is the most common cause. If you still have questions, please let me know. I hope this helps you.
Top Siemens Washing Machines Experts
vince
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
