Question about Sansui Televison & Video
My Sansui SLED-55-FHD does not respond to the remote.Remote tested OK.Is there a setting on the tv or the remote which can solve the problem
6ya staff
SOURCE:
Anonymous
SOURCE: 2002 Toshiba 32" TV
I have the same problem with a 2005 Toshiba. Got a new remote...nothing. Seems like a lot of people are having this issue, must be a defect in the TV. Has anyone contacted Toshiba?
Posted on Feb 06, 2008
greenspan
Remmy Moore
  • 1734 Answers
SOURCE: Sansui TV code for a rm-ez4 remote
Ask Manualfox.com - it is a personal Document Search Service for electronic user, service manuals and drivers. They help you to save time and money by finding your needed product information.
Posted on Feb 22, 2009
Anonymous
SOURCE: sansui tv remote code ALLFORONE Universal Remote URC2020B02
i have a one for all remote how do i program it to a sansui tv
Posted on Dec 19, 2009
supernova278
Udhaya Rajan
  • 1932 Answers
SOURCE: can't find code for my sansui tv and rca universal remote
Code for Sansui TV are
1247
1191
Please try the above codes
Thanx
Posted on Jul 25, 2010
gopakumarg43
  • 76204 Answers
SOURCE: T.V. remote sensor not working
Hello
If you are sure that the fault is with the remote sensor of your TV, replace it with a new one. The remote sensor can be located just behind the remote sensor window at the front panel of the TV. You nave to open the TV to access it. It is a three solder terminal component. It will look somewhat like this, having brownish black in colour. This component can be bought from most of the electronic spare part selling shopw at your town; very cheap to buy too. OK
Posted on Nov 28, 2011
Im trying to program the rca remote to my tv
Try any of the Sansui TV codes.
Sansui might be buying in some other brand of TV and rebadging it. Try the code auto search feature from the remote.
RCA code finder and support is here: http://www.rcaaudiovideo.com/remote-code-finder/ Download your user manual and have a read of the instructions.
Sep 09, 2014 | Televison & Video
Are there any universal remotes on the market that access setup menu and are able to change settings for the Sansui dftw275? I bought a Magnavox universal remote, but will not change settings.
Hello
Select one [One For All URC - 3021, universal remote control. Sansui is lited in its codes. You will get its catelogue and user manual which contains all proceedings about how to setup with it your Sansui TV.
The code for Sansui is
[0463]
OK.
May 05, 2011 | Sansui D 27" TV275 TV
I have a Sansui SLED 2280 that I'd like to use without cable input. How do I switch to regular over the air (no cable) antenna? Thanks
To switch from cable to air or vice versa on most Sansui flat screen tv's including the SLED2280, go into the menu. Select "channel" on the screen. Press "enter" on the remote. Select "auto ch mem" on the screen. Press "enter" on remote. Select "signal type" on screen. Press right arrow button or right volume button on remote to change signal type (cable or air). To program channels into tv, select "automatic search" on screen then press "enter" on remote. Wait for search to finish.
I hope this helps you.
Bobya
Dec 19, 2010 | Sansui Televison & Video
I am bibin from kerala i have a sansui tv model sv/2110 now it remote is not working i brought a new one but it also not working. some of the channel are locked so i can watch 3 channels only how can i...
Hello Bibin
Have you teseted the remote handset for infrared radiation? You just check it first. You can check it easly, if you have a cellphone, which has camera option. Put the phone on camera mode, and place the remote handsets' front end towards it lens, at about 1 feet away or so, press each button. If there is infrared signal, you can see its image on the phones' screen. If it is there and still your set is not responding to the remote control, iinfrared sensor inside is faulty. You know that component. Replace it with same type and number. Without remote control, you can't access many of the parameters of your TV. Ok.
Dec 11, 2010 | Sansui H TV2600 TV
I have a sanyo remote and a sansui tv how do i program the tv
Hello
I don't have a code for Sansui TV to be programmed with Sanyo remote control But hava a philips Universal remote model which can be programmed for Sanyo TV and has its codes.
Remote Model ===> Philips CL 034 Universal Remote Controller.
Codes
0115 0632
And herealong with I sends some universal remote codes, that you can check it for.
Four Digit Universal remote code for Sansui TV are
0135 0310
Three digit universal remote code for Sansui TV are
135/ 136
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Nov 25, 2010 | Sansui Televison & Video
TV is not responding to the remote control.
The set may have defaulted to a front panel lockout. To defeat that on the front of the set hold down the MENU button for 15 seconds and see if it will then power up. I know that doesn't solve the problem with the remote but one step atta time. These sets are prone to leaky switches on the control panel and when that happens the micro cannot accept two different commands at the same time. That could be why the remote is not working.
Apr 05, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Need code for Sansui TV
sansui: 1929, 1911, 1904
or use the general programming tool:
SEARCHING FOR YOUR CODE
If your device does not respond to the remote after
trying all codes listed for your brand, or if your
brand is not listed, try searching for your code. For
example, to search for a code for your TV:
1. Press TV once.
2. Press and hold P until the red LED blinks
twice, then release.
3. Enter 9 9 1. The LED blinks twice.
4. Aim the remote at the TV and press Power.
The remote sends IR codes from its library to
the selected device, starting with the most
popular code first.
5. If the TV responds, go to step 6. If the TV
does not respond, press CH+. The remote will
try the next code. Continue until the TV
responds.
NOTE: Press CH- to try the previous code.
6. To lock in the code, press P once. The LED
blinks twice.
7. To search for other device codes, repeat steps
1 to 6, substituting the appropriate device
key.
Mar 31, 2009 | Radio Shack 15-2142 Remote Control
Televison & Video Logo
Top Sansui Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
