Philips 47PFL3603D/F7 LCD HDTV, 47 Diagonal Size, 1920 x 1080 Resolution, 1080p FullHD Display Format, 16:9 Image Aspect Ratio, 29000:1 Dynamic Contrast Ratio, 500 cd/m2 Brightness- cd/m2, 178 degrees Viewing Angle, 5 ms Pixel Response Time, 3D digital Comb  Logo
R
Rodney Shepherd Posted on Jan 15, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
47pfl3603d/f7. TV screen has been going black for some time.Now when I try to turn it on it has sound but the screen is black and will not show a picture at all .
Level 3:
Top Expert:
  • Philips Master 76,851 Answers
  • Posted on Jan 16, 2017
Philips Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15004949
Points
237762
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
T-Comtech Repairs
Level 2:
Guru:
  • Expert 417 Answers
T-Comtech Repairs
Expert
Level 2:
Guru:
Answers
417
Questions
Helped
110994
Points
317
THE SCREEN INVERTER HAS GONE, TYPE THIS INTO EBAY :
47PFL3603D INVERTER
I have a 47" Philips LCD TV Oct 2008 Model # 47PFL3603D/F7 When I turn it on, it works fine for about an hour or so. Then the screen goes black, not a fade right to black. Sound is still on.
The backlight inverter is built into the power supply of this unit. When it fades to black screen, do you see any backlight at all?
If you do see some light, you have a 'blank screen' problem and the backlight is not the cause. Since you can still hear sound and can control the tv otherwise, the problem is likely in the TCON board.
If there is no light coming out, perform a flashlight test (search YouTube for details on this). If you pass the flashlight test, then try replacing the power supply board.
47" philips lcd tv goes black but still has sound
Yeah the picture tube is old.... if it's a lcd or led then u're having prob's with display Circuits... call a techie and he'll fix it
Phillips 47pfl3603d blank screen with sound
if the Tv have back light the problem is t-con if not the problem is inverter
I am looking for all replacement fuses in for the 47" model, model # 47PFL3603D/F7
Best thing to do is contact a local tv shop, some fuses are specialized so its best to be sure you are getting the correct values. we sell them for a couple of dollars each.
Screen started to go black while watching the tv.
yes, by canging the bulb. it proboly went out while the television was already dead. you can try but i would hire a proffesional. it may cost 100$ or more.
Phillips 47PFL3603d-f7 blinks when turned on
Common short the cover cap over the video & sound boards short out if you remove it the cap only (shield metal) it usually will fix this
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
