Dyson Digital Slim DC59 and DC62 cordless vacuum cleaners are engineered to make a pulsing sound to let you know if they're blocked. This could happen if an item too large for the machine is accidentally vacuumed up. Our video support guide will help you identify and remove any obstructions from the motorised floor tool, wand or bin inlet.
It could be the filters need cleaned or replaced. Try turning it on without the filters on it, if it doesn't pulse on and off it may mean the filters are restricted and need cleaned or replaced. Do not use the vacuum without filters.
Hi, this happens when the PCB detects a blockage. Take the filter out and then try it. If it no longer goes for only 5 seconds then your filter needs washed. Wash the filter in your washing machine.
if fitting/ removing the filter makes a change ( filters no nothing but filter air), then the problem is the filter
if a new filter makes no difference to the problem , take it in to a sevice agent for repair
There are a number of reasons why your Dyson cleaner is pulsating off and on. First, it maybe due to a battery of the unit. Make sure that the power cable is properly plug to the power and seated properly from the unit while charging. If you find that the battery isn't charging at all, you may need to replace the battery. Second is to check the MAX button of your cleaner. If the button lights up and flashes when your Dyson keeps on pulsating, press and hold the power button and depress the MAX button to turn off the function. You may need to do it for a few times to get the hang of it. Third is to check for any blockages or clogs in the attachments. Look down through the tube and check to see if there are clogs on the sweeper end or if the roller is tangled up in fibers. Clean the roller brush are if it it's necessary. You may need to empty the dust bin of your unit as debris can build up in hard to reach places. Lastly, cleaning the filters may fix the pulsating of your cleaner. Remove the filter and rinse it with cold water and air dry it for 12 hours. Don't use detergent when washing your filters. If the pulsating doesn't go with the given quick fix, I suggest to contact Dyson for further assistance on this.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Your Dyson V6 vacuum is designed to make a pulsing noise to warn you when something is preventing airflow from passing through the machine. This could be a blockage in the motorised floor tool, wand or bin inlet. It's also a good idea to check the bin inlet flap can open and close freely, and isn't jammed in place.
Our video support guide will walk you through the simple troubleshooting checks:
I'm confident that removing any blockages and checking the bin inlet flap will resolve the issue with your machine. But if you would like any further help, just give the Dyson Customer Helpline a call on 1-866-693-9766 (US), 1-877-397-6622 (CA) 1800 239 766 (AU), or 0800 298 0298 (UK).
