If you use a fast charger, or a power charger, that can be the cause of your trouble. I used to charge with different power chargers till I learned they push every battery over its limits. After at least 3 different power chargers and about 100 defective batteries, I now charge my batteries with normal slow chargers. Before I can go on a shoot, sometimes 8 slow chargers are charging a whole night. But since I stopped using the power chargers I never lost a battery on overcharging (actually overheating)
go to www.dewaltservicenet.com and enter the model number of your drill. It will get you to the parts breakdown and will tell you if there is a charger available from the factory. Or call 1-800-433-9258 1-800-4DEWALT. stanley black and decker owns all of them so yes that's the right place!
If the charger got wet, or you tried to charge batteries that got wet... yes. Replace the charger, and throw away or recycle the water damaged batteries. I know thats not what you wanted to hear, but look at the bright side! The drill is most likley fine!
How old is the battery and do you store it in the cold. Cold is no good for the batterys but if its flashing that its trying to change and the problem may be with the charger if there not more then 3or 4 years old and were not left in cold conditions and the lithium battery haven't been out for much longer then that. Ihave the same gun and for a year its worked vary well with the 7 inch saw and i use them a lot.
Porter Cable has not offered a replacement for their poorly designed 19.2V chargers. I had the same problem and happen to like my drill and circular saw. I found a universal charger called a model number CHUN-2420. Google it--I got mine for $27 plus shipping. All you need to do to make this work is splice 3 wires.
My charger is a PC model 8624, so the instructions might vary slightly between the chargers. Remove the six screws on the bottom of your PC charger. Remove the bottom section. Remove the screw(s) that attach the circuit card to the plastic housing. Disconnect the 3 pin white charging connector from the circuit card, and cutoff the connector. Discard the circuit card and power cord. Cut the 3 conductor (red/yellow/black) cable coming out of the Chun-2420 approximately 2' from the charger. Splice these three wires to the three wires in the charger housing that connect to your battery. In my situation, Red/Red, Yellow/Yellow, White/Black. To verify, red=positive, black/white=negative, yellow=temperature sensor. Wrap the red/yellow/black cable with electrical tape where it exits the PC charger through the power cord hole. Re-attach the bottom.
Hello, Here's a copy from the owners manual: ■ Charging LED Red LED is on = Being charged Red LED is blinking = Charging error Green LED is on = Carging is complete
● If the charge indicator blinks as red, it indicates a battery charging error. - The battery is not properly inserted - The terminals of battery are dirty or damaged If the battery is inserted properly and the charge indicator continues to blink, contact the nearest Samsung Camera Service Center.
Another charging error is when the batteries are so depleted, they won't charge up to 100% anymore = red light doesn't go out and remains on for too long, means get a new battery.
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
the steady red light showing when in charger shows that
it is charging. the blinking red light when taken out of
charger or turned on and off means it is not fully charged.
leave it in charger till red light turns green.
