These free software updates include general improvements and performance enhancements. Note: Determine what Kindle E-Reader model you're using before ...
Manually Update Your Kindle E-Reader Software. Using a computer, download the file for your Kindle from Kindle E-Reader Software Updates. Turn on your Kindle. Connect your Kindle to your computer using the included charging cable. Drag and drop the downloaded update file from your computer onto the "Kindle" drive.
Kindle E-Reader Software Updates. Software updates automatically download and install on your Kindle when connected wirelessly. These free software updates ...
You can try different ways to update iOS. One of them shows below.
If a message says that an update is available, you could then click "Install Now" button to start to update your iPhone iOS software. Also, you could manually check whether there is an iPhone iOS update or not on your iPhone. The below steps would show you how to update iPhone software wirelessly:
Before you update iPhone software via WiFi connection, you need to make sure your iPhone has enough storage and battery to support the iPhone update.
Connect your iPhone to a WiFi network.
Tap "Settings > General > Software Update" successively.
Tap "Download and Install" option when your iPhone has detects an update available. If a message asks to temporarily remove apps because iOS needs more space for the update, tap Continue or Cancel. Later, iOS will reinstall apps that it removed.
Then iPhone would start to download and install iOS update immediately. You only need to wait for the update complete.
There are different ways to upgrade iPad. You can follow below steps to update your iPad with ease.
Of course, there are different ways to update iPad. You can follow below steps to do that.
Your Kindle Fire needs to be fully charged and connected to a Wi-Fi network before you can download the software update.
Tap the Quick Settings icon, and then tap Sync. The software update automatically downloads in the background, and installs after the download is complete and the device is asleep. Your Kindle Fire will restart during the software update.
To update you will need: 1 iOS tablet (iPad, etc) 1 wifi internet connection 1 power source
1. power on your tablet device. 2. connect to the wifi internet connection. A. Open settings B. Open general C. Select "software update" You should now see what update is available. If you are below iOS 7, you will need to update to version 7 to be able to see iOS 8 as available on some devices. 3. Locate iOS 8.x.x (on my tablet it is 8.1.3 as I wrote this) Make sure your tablet is plugged into a power source (you don't want it to lose power while updating) 4. Under the iOS update you want to install, select "install now" "download now" or "download and install" 5. Select "agree" when presented with the terms and conditions
You should see your device "downloading update" or "verifying update"
I have seen occasions where it will download but will not install until the process is repeated. (On one device I had to "install now" 3 times because the update failed to download or failed to install.
There are two ways to upgrade the iOS version of your iPad:
- via connecting the device to iTunes on a computer
- or directly from within the device, but only since iOS 5, it is possible to upgrade the iOS version without the need to connect the iOS device to a computer (over-the-air update)
just go to: settings - general - software update
There are two ways to update the iOS version of your iPad 2:
but only since iOS 5 it is possible to update the iOS version without the need to connect the iOS device to a computer (over-the-air update)
Go in settings go to general software update....connect to your wifi connection and update it will automatically detect the version required and go for updates
