SOURCE: Fisher & Paykel smart drive
Turn machine OFF on the front panel. Hold down the Water Temp Down button and press the POWER button. Release buttons. You are in Diagnostic mode.With your service sheet ,Diagnostic chart will explain where the error lights pattern and the path to your solution are.My advice is this....there is a known problem with the wire harness connectors,and the contact that is made at the point of connection.One at a time remove each connector starting at your main control board ,some where there is a loose connection.
SOURCE: We have a Fisher & Paykel Smart Drive 9
Thank you to the gentleman who sent us the Manual. We now know that F & P has an automatic Lint Filter which is pretty useless !! Oh, for the old method of a physical filter you can clean...
SOURCE: Fisher & Paykel washer GW712 won't spin
There is an issue with your drainage area. Best to remove the pump and check for the obstruction in the line or at the impellar.(If the water is not completely drained, the pressure switch wont send a low level to the timer to allow a spin).
SOURCE: fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
SOURCE: Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
