Question about LG Washing Machines
My lg tromm model number wm2277hw/01 has the error code le show 2 seconds into the cycle even if nothing is in the washer what is going on
  • LG Master
  • 2,522 Answers
Hall sensor needs replacing (motor position sensor). Pretty easy and under$20. Check out appliancepartsproscom, repairclinic.com or YouTube for how to videos.
Posted on Jan 22, 2017
6ya staff
SOURCE:
Annoying LG Tromm wm2277hw "LE error" won't go away.
Might be "tE" error code. Thermistor error. A $6 parts and pretty common and causes the symptoms you described.
Mar 02, 2017 | LG 4775er2002a Door Hinges for Wm2277hb...
LG Tromm WM2277HW will not spin both directions, LE error.
clean filter check that its drained all the water out any blockage and the machine will not spin
Nov 28, 2011 | Washing Machines
LG Tromm WM2277HW will not spin, LE error
the pressure switch is jammed on meaning the water has not empty le reading the is excessive water in the machine
Nov 28, 2011 | LG WM-2277HW Front Load Washer
I have a Lg WM2277HW front load washer. I replaced P/N 6501KW2002 (hall sensor), unfortunately still recieving error code LE. I even ran normal wash cycle no spin and 3 rinse and spins w/ no spin to...
Make sure hall sensor is snapped in to correct location and is secure. Take a look at repair videos from repairclinic.com or appliancepartspros.com for guidance. And the error code is "LE" for sure not "tE" which is sometimes confused between the two.
Apr 29, 2017 | LG WM2277H Front Load Washer
"LG Tromm WM2277HW will not
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall effect sensor is used in these washer which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when their is an issue with the motor or when the hall effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sesor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
Mar 27, 2011 | LG WM-2277HW Front Load Washer
LG Washer Model #wm2277hw
It is a motor error
• The connector in the LEAD WIRE ASSEMBLY is not connected to the connnector of STATOR ASSEMBLY Reconnect or repair the connector • The hall sensor is out of order/defective. Replace the STATOR ASSEMBLY
Apr 19, 2010 | LG WM-2277HW Front Load Washer
LG TROMM displays LE
LE stands for Load Error,
First try unplugging the machine for a few minutes and then retry a cycle. If you still get the LE error:
The Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in the US). Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000
Jun 21, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm washer LE code
I shouldn't even respond to this if you have had 5 or 6 tech look at it because I don't want a Thanks for Trying, but it sounds like you are at the end of your rope. The pump motor should not have anything to do with the problem. If you did not have anything in the tub, including suds, doing the QC test, and you have checked and replaced all you have said, the only thing left is the main PCB part number 6871ER1078T
Oct 25, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LE error
try using a-fresh its should help you out.
Oct 12, 2008 | LG WM2688HWM TROMM SteamWasher
Error message displayed on LG tromm washer model # wmt2778w
Flashing UE - The display shows:
• Load is too small.
• Load is out of balance.
• The washer has an imbalance detection and correction system. If individual heavy articles are loaded (bath mat, bath robe, etc.) and the imbalance is too great, the washer will make several attempts to restart the spin cycle. If an imbalance is still detected, the washer will stop and the error code will be
displayed.
Possible Solution
• Add 1 or 2 similar items to help balance the load.
• Rearrange items to help balance the load.
• Control error.
Nov 07, 2007 | LG WM-2277HW Front Load Washer
Washing Machines Logo
44 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
