The itchiness between your toes can be triggered by many things. Athlete's foot is one of the most common causes. Sweating heavily is also the main cause but dyshidrotic eczema, contact dermatitis, and insect bites can often cause itchy flare-ups, too.
Make sure you do something to stop sweating, No matter what, try to resist the urge to scratch any itchy spots between your toes. Scratching could tear your skin and leave you vulnerable to infection, which could add pain to the itch.
If home treatments like anti-itch lotions, cold compresses, and moisturizers don't help relieve the itchiness, or if the itching gets worse or spreads, be sure to follow up with your healthcare provider to get the right treatment.
Sweating and itching are the two main causes of skin burning , this could be the reason in your case. It is important to prevent them. If you want to use natural remedies then baking soda is the best option. It is the best option to use between your toes. Rub in the paste and rinse thoroughly. But, I would also suggest you to pay a visit to skin care expert for the skin burn treatment as per your skin type. As they detect the skin type and then go to the medication for that. So you may get the customised solution for your problem as per your skin type. Hope this helps.
Hyperhidrosis Treatment Reduce Excessive underarm Sweating Kaya Skin...
Skin conditions that cause the feet to itch include: allergic contact dermatitis, which can be caused by something like new laundry detergent. It's important to cure toe itching because it may cause the infection and that may affect your skin or you can cure this infection by naturally. You can use tea tree oil soap to cure this itching.
