SOURCE: Toner empty error message on brother mfc 8220.
OK
Here's what you do if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below.
The display will show "REPLACE DRUM - 1.YES 2.NO".
SOURCE: What is a waste toner box. what does it do and. BEWARE THIS NUMBER 1-800-975-0148 IS SPAM HERE
like the name suggest, it collects waste toner. Any toner that is left over from the print process is waste toner. Once the waste toner bottle is full, the printer will stop working until You have replaced it with an empty waste toner bottle. So in short, if it is telling u to get a new one, get one or the other option is to empty it yourself which is very messy and if u dont clean the bottle of all toner dust, may not even work.
Testimonial: "I had no clue what a waste toner box is. Your response helped me. Thank you."
SOURCE: brother 4070cdw waste toner is there a way to
Messy.
Best to replace the waste toner collection unit.
This is a user replaceable, consumable part.
SOURCE: I replaced my waste toner box in Nov 09, ever
Make sure the box is in the unit correctly and is completely seated in its holder. Either one of these could result in the unit not recognizing that you have replaced the bottle.
SOURCE: I keep getting either a No Waste Toner, Print
2a is a belt cleaner release failure. May need a new waste toner box, or check the release lever for the waste toner box.
