Everything seems to run fine, just hasn't pulled a drop of water
Bought it a year ago, seemed to work decent. Started it up this year, and everything seems to "sound" fine, the compressor turns on, the fan turns on... but its been running for 4 days now, and no water.
Re: Everything seems to run fine, just hasn't pulled a...
Remove the back airfilter, and touch the tubes while the unit is running, if nice and cold, all is well, there just isnt any moisture there. but if compressor is running and tubes are warm , means freon/coolant has leaked out
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
If has not produced a drop of water for several years, then it's not working properly. But, this may be a case of setting the humidity level to high. In other words, if you set it at 70% or Maximum, that's the humidity level that it will maintain, not remove. To remove humidity, the level must be set low (35% or Minimum).
To test the unit, based on what I just said, place it in the bathroom, set the level as low as possible and turn the shower on medium hot. Do Not turn the bathroom exhaust fan ON. As you leave, close the bathroom door. Return in 15 minutes, turn the shower OFF and check the bucket water collected. If there's any water in it, it's working fine. It was probably a case of the humidity level being set to high.
Hi, There are many reasons for a dehumidifier tto not work or collect water. Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
I have the same problem, just started it after not using it for the winter and it runs and runs and no water. I believe the coolant has leaked from the sealed system and there is nothing you can do. I've had it for 1 year and it has a 5 year warranty. I know from experience, this is the 3rd dehumidifier that I have had this problem with, all different brands. Call for service, I am betting you have not had it very long.
most probable cause of a dehumidifier not collecting water when it appears to run fine otherwise is a dirty heat exchanger. It is unlikely that a huge spread in the time a unit works is caused by failure of the compressor of loss of refrigerant. On the other hand, people use their units in very varied conditions of dust in the environment with expected short to long operating times before failure. Here's how to fix this problem in two steps.
Step 1: Determine if your compressor and refrigerant sealed unit is operational
Step 2: If Step one is negative, dispose of the unit - specialized equipment is required to repair or recharge a compressor. If step one is positive, then clean the heat exchanger.
This site did not allow me to post the full instructions because they exceed an unspecified upper limit to message length. What a waste of time. In order to be helpful, please contact me at [email protected] and I will email you a file with a complete set of instructions. Cheers.
Unfortunately this is quite common for most DH's of this type. The only one that I have found that does not have a reputation for losing the fan or compressor after a year or two is the Whirlpool.
I have the same dehumidifer - make and model. I bought it less than a year ago.
It too runs fine, but now collects no water.
Did you ever discover how to fix the problem?
