SOURCE: no sound when phone rings
I called Verizon Wireless and the said, if you go to “My Sounds” or “My Ringtones” select the song that you want to hear and press the play button. While the ringtone is playing press the button on the side of the phone to raise the volume…you should be able to hear the ringtone. Hope this helps!
SOURCE: Pantech C120
change the speaker on the phones and also have the ringer check on the main-board.
SOURCE: Panasonic KX-TD7896 Phone phone no longer rings only vibrates
Is there an 'M' on the display? If so, that means it is in 'meeting mode.' All you have to do is press and hold the star key (*) and that will take care of it.
SOURCE: can't get speaker volume or audible ringtone
sir
dismantle your phone and clean the contacts of the speaker and buzzer or replace them... it will solve your problem
