No previous problems. Was about 2/3 gauged by time through it's cycle when it stopped its function and started beeping.
SOURCE: Dishwasher LD-14AW2, stopped working mid cycle
Since water doesn't drain out ,it could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. Good luck!
SOURCE: smeg di612ca (e2 error msg)
http://ukwhitegoods.co.uk/modules.php?name=Reviews&rop=showcontent&id=20
Under installation it mentions this problem
http://www.smeg-service.co.uk/support/index.php?a=1&cat=4#5
list of error code explanations
SOURCE: E2/F2 Error
The door lock that is normally used in the self cleaning cycle is locked all the time. You can open the door using a paper clip to trip the latch and the oven operates normally. Can I cut the latch off and not affect the cleaning cycle?
SOURCE: Kenmore HE4t Won't continue drain cycle Code F6 & beeping
Take off the bottom panel (unplug unit first!) and unscrew the cap on the drain cylinder, be sure to have plenty of towels to soak up the water! pull out the center piece and check out all the treasures stored inside. Be sure to use a flashlight and lift up the black hose behind it to get any leftovers in the hose. I just did it today and could not believe how much stuff was in there...coins. pens, buttons, lost of wet lint had it clogged. The clothes finally don't smell!
SOURCE: error code E2
Error Code E2 means the pump is blocked. The remedy is to take the filter out which is underneath the bottom dish basket and ensure its is clean and free from debris. Then use a small container to empty the water sitting in the bottom of the machine/filter housing and ensure that no waste is stuck in the bottom. That should clear it
