azaharuddin ansari Posted on Jan 30, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
1580mf peint unable EF
Konica minolta pagepro 1580mf print unable EF
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Mar 11, 2017
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1910664
Points
11959
What is ef
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5 Related Answers
Anonymous
  • 214 Answers
  • Posted on Jul 02, 2008
SOURCE: konica minolta pagepro 1350w error light won't stop flashing
pleas install status monitor, it will tell you what is wrong
Anonymous
  • 3 Answers
  • Posted on Apr 16, 2009
SOURCE: konica minolta 1350w status display comes on at start up
Open c:\windows\system32
find a file called MSTMON_Q.EXE
right click and rename the file to anything with a file extension .exe, I named it MSTMON.EXE
Create a shortcut to this new file in case you need it in the future and put the shortcut on your desktop
also, write the original name of the file down or put it on notepad, in case you want to change it back.
restart windows
freetek
Steve Allison
  • 5569 Answers
  • Posted on Oct 10, 2009
SOURCE: konica minolta pagepro 1350w fatal print spooler
A 'print spooler' is a range of memory either internal to the printer (sometimes called 'buffer memory') or set aside from the RAM in your system. A fatal error normally means the material you tried to print has been lost and must be sent to the printer again. If the error continues to show up, you may have bad printer memory or perhaps the driver software in your system has gotten stepped on by the operating system and needs to be reinstalled. Windows loves trashing files to keep life exciting.
This problem is not related to the drum or toner cartridge.
xeerie
Zaheer Ahmed
  • 347 Answers
  • Posted on Jun 19, 2010
SOURCE: i want konica minolta pagepro 1300w wondows 7
try universal drivers from www.mykonicaminolta.com
xeerie
Zaheer Ahmed
  • 347 Answers
  • Posted on Oct 20, 2010
SOURCE: DRIVER NEEDED: KONICA MINOLTA PagePro
http://onyxftp.mykonicaminolta.com/download/Search.aspx
search in this link.
How do i refil konica minolta pagepro 1500w
Buy OEM CARTRIDGES. The cart ridge have sensor on the machine can tell used from new
Konica minolta pagepro 1350w not feeding full page but get stuck at half page.
check the size of the document make sure the print drivers and the printer are correct and matching you might also need to replace the fuser unit or the transfer roller and or image unit
How we reset printer konica minolta 1390
About 88,000 results (0.73 seconds) Search Results
    [PDF]PagePro1380/1390 MF Service Manual - Printers - Konica ...
    printer.konicaminolta.net/drivers/other/1390/1380_90_fs.pdf
    the risk of damage to the product, KONICA MINOLTA BUSINESS TECHNOLOGIES, INC. (hereafter called the KMBT) strongly recommends that all servicing be ...Missing: we
    [PDF]PagePro 1390 MF Printer / Copier / Scanner User's Guide
    images10.newegg.com/User-Manual/User_Manual_28-117-006.pdf
    PagePro is a trademark or registered trademark of KONICA MINOLTA. PRINTING .... Print Media 20. What Sizes of Media Can I Use? 20 .... Stop/Reset key. Exits the menu. ... Right-click the KONICA MINOLTA PagePro 1390 MF printer icon.
    [PDF]Technical Guide - Printers - Konica Minolta
Konica Minolta Pagepro 1350 page count or Print Config sheet?
please go printer utilty option on your pc then you can print a testpage
2answers
KONICA MINOLTA PagePro 1350W
the problem it might not be the printer. I encounter this problem before. the solution is uninstall the print driver to the control panel and re install the print driver using the cd print drive or you can download to konicaminolta web site..
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
