SOURCE: problems transfering apps from iphone to Ipade
You are able to use any appstore app with the iPad. Make sure your iPad is listed as a connected device in the left side bar of iTunes. Check your sync settings to make sure they're set to sync with your iPad and if needed restore your iPad using the restore button and try to sync again.
To make an application fullscreeen tap the small "2x" button in the bottom corner of your iPad. This will upscale the app to fullscreen.
Hope this helps, if you found this helpful please leave some feedback. Thanks.
SOURCE: Apple Ipad screen isn't working
If the issue persists after a restart, there may be an issue with your digitizer / touch panel. Apple willhelp you with this because it is so new. However if you dropped it in water (etc.) and if apple doesn't replace it for you, You can get the digitizer at iPad Repair and there is a guide that shows you how to put in the part at Electronics Repair Guide.
Testimonial: "thanks"
SOURCE: My WritePad app for IPAD no longer separates
If the spacebar on the keyboard isn't there (with .com and underscore keys etc instead), you're in the URL-typing keyboard instead of the normal one. Try clicking the @ icon in the bar just above the keyboard to change modes. In handwriting mode, it's the same thing...click the @ icon near the left side of the bottom bar.
SOURCE: Want to delete apps on ipad
On the app you want to delete hold it down until the apps starts shaking and a cross will appear in the apps you can delete. Click on the cross and it will say delete "name of app", then select the delete button. Once you have done this, press the home button to go back to normal. Hope this helps.
SOURCE: iPad shows blank black screen & won't turn off ~ how do I fix?
Try reseting the iPad by holding the home and power buttons simultaneously until the iPad completely shuts down and the Apple logo appears.
Once the Apple logo appears you can release the buttons. If this does not work, you may need to connect your iPad to your computer and do a factory restore using iTunes.
