Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
Posted on Jul 22, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Stopped near end of cycle, water in bottom and no lights will come on when pressed
Anonymous
Level 2:
Sergeant:
  • Expert 296 Answers
  • Posted on Jul 22, 2009
Anonymous
Expert
Level 2:
Sergeant:
Answers
296
Questions
Helped
89961
Points
895
Hi
seems there is probably water in the drip pan below that needs to be emptied or evaporated out. but if there is water ther is an internal leak such as a bad hose or door seal thats need to b fixed.
unplug the unit or open up the bottom behind the toe kick and **** out all the water and find the leak by running it with the cover off till you see it.
hope it will work for u
all the best
,for further queary ,plzz do let us kno.
regards
Machine will not finish any wash cycle, It stops, illuminates END light and beeps? Is there a reset or is this at the end of it's life?
Hi, quite often cycles are not finished because the drain pump has an intermittent fault. It may pump ok at the start of the cycle but towards the end it's had enough and stops. Leaving water in the bottom of the drum. If this is similar to your machine's symptom then I would be checking the pump. They are cheap to buy and easy to fit.
Hope this helps you.
1helpful
Dishwashwer continues a motor noise long after the quick rinse cycle ends
Hello Deborah!
Well, don't use the quick rinse cycle!
All seriousness aside, dishwashers are supposed to stop on the pump out cycle when the water level switch trips, indicating the tub is nearly empty (a little water always remains to protect the seal).
Why your problem exists only on quick rinse is a mystery, but I would check the water level float mechanism. They have a way of accumulating grunge and sticking. While many float switches are easily accessible in the front, bottom corner of the tub (and "click" as they are raised and lowered), some live in a container on the outside of the tub and may only be checked by pulling the whole dishwasher out.
All the best.
Dishwasher wont completely drain and turns off
Good Morning Friend,
I understand that your Frigidaire dishwasher shuts off near the end of the cycle, leaving water in the bottom of the tub. I also see that the display is going black. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 20-30 minutes. When power is restored, run any cycle. If you are still noticing your dishwasher shutting off towards then end of the cycle and water being left in the tub, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine what is causing it to shut off and not drain. Hope this is helpful.
-Best regards-
WP
Kenmore Dishwasher has died part way through a wash cycle.
The control module has failed, you can check for broken solder joint s or obvious damage but it's hard to diagnose the exact cause remotely.
Mar 12, 2012 • Dishwashers
F27 came up nearing the end of the spin cycle and just stops after it's spun but doesn't finish and release.
Close the washer and press the START/PAUSE/Cancelbutton to remove error displayed and restart the cycle. If it doesn't work, it means thatthe valve at the water entry needs to be replaced..
Hope this helps..
Close the washer and press the START/PAUSE/Cancel button to remove error displayed and restart the cycle. If it doesn't work, it means that the valve at the water entry needs to be replaced..
Hope this helps..
2helpful
2answers
What is E25 on my Bosch super silence dishwasher?
I quote same wrong from other user:
Question: Model dishwasher is Bosch Exxcell SMS50E02
It stopped before the end of a cycle with the error code E:25 and the "check water" light came on
I mopped out all the residual water out of the bottom and then ran a rinse cycle, which after several trials I got to work and then it stopped at the end again with the same error code and water in the bottom as before.
Answer:
I assume by in the bottom you mean inside the dishwasher and not in the base.As long as there is no debris in the sump area and the hoses are clear it appears you have a bad drain pump.
Hope helps.
Apr 03, 2011 • Dishwashers
Condensation in dishwasher
Make sure you aren't selecting the eco setting to conserve power. Running a dishwasher in that mode disables the heating element that dries the dishes at the end of a cycle. Here a few ideas you can try,... with an empty dishwasher.. start a cycle and make sure you do not use that ECO mode if it has that feature.. then stop the dishwasher when it near the end of the cycle and open the door ./.. check to see if the water has been drained and that the heater element is on and hot. If there is a high volume of water in the bottom of the dishwasher, make sure the darin filter screen is clean and not restricting water flow... If that is clean.. and you have a lot of water in the bottom pan, you could have a problem with the pump, a hose in line with the pump or your house drain system is restrictive.. Good luck... and Hope this helps you..
1helpful
The dishwasher has been running for 3 hours and seems to be stuck on 1 minute left. Upon opening, there was sudsy water remaining in the bottom, but the dishes looked clean. The washer just won't go to...
SHU 53 MODELS To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button. To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show ?88″ when REGULAR WASH button is pressed and ?8h? when Delay Start button is pressed. To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4). 0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault 1 = Aqua Sensor (?Sensotronic?) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test) To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty. If water level switch (f1) has failed (opened), display will show fault code ?4″ and unit will continually fill and drain where testing won?t be completed. If flow switch (e5) has failed (opened), display will show ?0″, water won?t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code ?8″ immediately and testing will end shortly after water has started circulating.
2helpful
LG Dishwasher Model LD-1403W gets stuck and stops on rinse cycle leaving water in bottom of machine. I have stripped it down and emptied it, made sure filters etc are clean but to no avail
LG Dishwasher LD 1403W. We have cleaned it and when it gets to the heating cycle after running right through to nearly the end, it trips all the electricity and stops everything. Its only 3 years old and hubby thinks its the heating element but between $200=$300 to fix.
Apr 10, 2008 • Dishwashers
Top Kenmore Dishwashers Experts
vince
Paul Carew
NOEL
NOEL
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
