Thats an error code for the drain pump, if it drains a bit of water then stops the drain pump is faulty (usually overheating coils from corrosion especially if you get a hot metal smell when it happens) dont keep doing it as it has tendency to blow the control board, you will need to replace the drain pump
SOURCE: Fisher and Paykel GW712 Washing Machine - beeping & flashing continuously
my gw712 washing machine will fiil up ok but then it wont spin properly it only spins a fraction then stops and starts beeping the second led from the left starts flashing. any help would be greatly appreciated.
SOURCE: Fisher & Paykel Pride 5.5
Hi - the out of balance switch has activated this will be found under the lid right side if you bend lw enough you can see it hanging by a lever - it may have activated from the previous cycle - it needs to be freed - put it outside of the bowl and be sure its free to operate - if not it needs to be removed and replaced.
your clothes load is too heavy on one side; stop it move some around and turn it back on and see if it doesn't wobble all over.
