Question about Kyocera Office Equipment & Supplies
My kyocera task alfa 180 is printing blank, how can i fixed it back
I remove the drum unit and developer unit, when i fixed them back it started printing blank
    Champion:
    New Friend:
  • Kyocera Expert
  • 250 Answers
If you installed new developer unit you have to initialize it or else there wont be any or enough toner in the developer so its going to always add toner or print light or blank copies
Posted on Mar 21, 2019
6ya staff
SOURCE:
Anonymous
  • 21 Answers
SOURCE: how to remove drum unit
Installing the Toner and Drum Cartridges
bullet.gif Installing the Toner Cartridge
bullet.gif Installing the Drum Cartridge
caution.gif CAUTION: Before performing any of the following procedures, read and follow the safety instructions in your Owner's Manual. Installing the Toner Cartridge Install or replace the toner cartridge while the printer is on (if the power is not on, the cartridge carrier will not rotate).
  1. After confirming the Insert Yellow Toner (Y)message, open the front door.
  1. Hold the tape on the protective cover and pull it forward to remove the cover from each cartridge slot.
note.gif NOTE: You need to remove the protective cover only the first time that you install the toner. note.gif NOTE: Dispose of the protective cover after you remove it. note.gif NOTE: The protective cover is attached to each toner cartridge mount. mag_cover_5.gif
  1. Make sure the color of the toner cartridge matches the slot on the toner cartridge carrier. The order is Y, M, C, K. Gently shake the cartridge to distribute the toner evenly.
  1. Lift the tab up 90 degrees and pull the toner seal straight off, keeping it parallel with the toner cartridge.
  1. To insert the toner cartridges, align the arrows on the cartridge with the corresponding arrows on the printer. Guide the cartridge in until it snaps into place and then push down the handhold to lock the cartridge in place.
  1. Close the front door.
note.gif NOTE: Make sure the toner cartridge is installed correctly. Otherwise, the front door cannot close firmly. close_front_cover.gif
  1. The toner cartridge carrier rotates to the next empty slot. When the color of the newly inserted cartridge appears on the display, followed by the Insert message, insert the next toner cartridge.
  2. Repeat steps 1 through 7 when inserting the remaining cartridges.
  1. When the Insert Drum or Insert Drum Cart message appears, open the front door, then lift and push back the top cover.
  1. Remove the protective sheet from the drum cartridge.
  1. To insert the drum cartridge, push up the lever on the right side of the printer. With the lever in the upright position, hold the drum cartridge by the handle, align the arrows on the drum cartridge with the corresponding arrows on the printer and guide the cartridge in until it snaps into place.
  1. Pull down the lever on the right to lock the drum cartridge in place.
  1. Close the top cover, then the front door.
note.gif NOTE: After installing the drum cartridge, the printer makes an adjustment for about one to two minutes. Do not turn off the printer during this time.
Posted on May 29, 2009
FixinFax
Leroy Elliott
  • 3085 Answers
SOURCE: kyocera 3035 printing all black pages
It sounds like you have a bad charge corona.
Posted on Jun 13, 2009
Andy
  • 44 Answers
SOURCE: I´ve got a message on my oki C5510 mfp
Check the toners are not empty. The printer only estimates how much it thinks should be left, there is a possibilty one is empty. this is best done by removing each toner in turn and checking that the hopper in the drum is full to level with the sponge surrounding it. Next check are the toner sensors. These are small and located to the right of each toner cartridge in the wall of the printer, one could be dirty creating the error and not allowing the printer to start up completely, causing the scanner connection to fail and giving you "Failed to get printer information". On this model the scanner and printer are essentially separate units joined by a USB cable.
Posted on Nov 08, 2009
Anonymous
  • 14 Answers
SOURCE: Kyocera Fs-3900dn is printing with black lines
Check if you have not reached the specified limit of printed pages for service of the cartrige and or the drum!!!
Posted on Nov 26, 2009
n25an
Norman Davis
  • 622 Answers
SOURCE: Kyocera FS-3900 and FS-4000 Prints very faint. New printers affected
sounds good
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Posted on Dec 24, 2009
I need a keyosara task alfa 180 services ook
I think the Kyocera copier service manual you are looking for is available for download at http://www.copytechnet.com
Apr 19, 2014 | Kyocera Office Equipment & Supplies
I have a kyocera 180 copier does not print texts even when we do internal print. it's blank when copying. We change DRUM, TONNER, DEVELOPER and MOTHER BOARD but still the same. Is there any other thing...
I have a kyocera 181 copier when we switch on the machine it showing error message " shake the toner container' kindly do the needful or send me service manual as soon as possible
I am awaiting for valuable response....
Sep 18, 2013 | Kyocera TASKalfa 180 Copier
Master reset code Taskalfa 180
Kyocera mita task alfa 1800..error code 0800
Jan 18, 2012 | Kyocera TASKalfa 180 Copier
Error code 7410:0167274 on a Kyocera FS2000D, what does this mean?
The 7410 indicates a drum error (see below) the 0163053 is the number of prints made by the printer. The drum was most likely knocked loose when installing toner.
Drum unit non- installing error -
The drum unit is not installed or not installed properly.
Detaching and refitting the developer unit Procedure
1. Open the top cover.
2. Open the MP tray.
3. Remove the developer unit.
4. Check or replace the developer unit and refit all the removed parts.
Detaching and refitting the drum unit
1. Remove the developer unit.
2. Open the left side cover and then remove the waste toner box.
3. Unlock the drum unit lock and then remove the drum unit.
4. Check or replace the drum unit and refit all the removed parts.
I hope this is helpful,
Shawn
Jun 10, 2011 | Kyocera FS-2000D Laser Printer
Kyocera FS3900DN changed toner and got error 7410:0163053 to call for service
Shawn
Feb 25, 2011 | Kyocera FS-3900DN Laser Printer
My kyocera taskalfa 180 showing c6400 error please help.
C6400 is a fixing unit error.
To reset -
Try this, enter "10871087" from keypad, You should now be in maintenance mode.
Enter "163"press "Start / Print" key.
You should see a screen that says "Execute".
Cursor / highlight "Execute".
Press "Start / Print key.
The machine will turn off and should come back to ready. If not then you need to replace the fixing unit.
Shawn
Feb 25, 2011 | Kyocera TASKalfa 180 Copier
HI there! Our Kyocera 180 does not photocopy documents. The paper that comes out is just blank. We recently replaced the tonner so we believe there's still enough ink. Should we checked if the photocopier...
if you are getting blank copies nothing on the page you need to check the drum main charge or the developer unit is locked into place correctly and if the developer unit is turning take out the developer unit and see if there is an even coating of dev and toner on the roller use a piece of paper rub of a small are on the developer roller put in the machine and do a copy after take out the developer unit and see if where you marked is visable if it is then the developer unit has a problem as it is not turning
Check the main charge roller it is connected to the side door
Feb 05, 2011 | Kyocera TASKalfa 180 Copier
Missing developer unit
Generally this printer can be separate into 4 major part: Printer body, Toner container, Developer unit and Drum unit. The developer unit is the unit where the toner container "mount" on it and it should be removed to allow cleaning task every time the toner container is replaced.
U may get this error message if the developer unit is not install properly after u replace a new toner container. Just lift the developer unit together with the toner container out of the printer and then insert back properly into the machine.
YBC (/\)
Jun 03, 2008 | Kyocera FS-920 Laser Printer
428 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
