Question about IPACS Aerofly 2 Flight Simulator
I have Aerofly 2 Flight Simulator on iPad Air2 and Gamevice controller. How do I control the throttle? I cant use the throttle with the controller or touching the screen.
I am playing Flight Simulator X Gold Edition. On my Logitech Attack 3 joystick, what is the throttle control level number? Please help!
I have the same stick, the throttles are actioned by the little levers in front of you at the bottom of the stick, I dont quite understand what you mean by level number...
all you have to do is configure them in the configuration panel of the flight simulator, I use same simulator for practice.
Aug 19, 2011 | Logitech Attack 3 Joystick
Saitek pro flight yoke problem
This is a know fault on Saitek yokes that is now cured. take it back and explain that it is suffering from "Ghost button pushing" and they should change it for a unit that has been updated. This problem is well documented on the web.
Jun 05, 2010 | Saitek Pro Flight Yoke System Flight...
Speed doesn't work
no the buttons does not have anything to do with this, first you need to recailibrate the flight yoke. then go back into flight simulator and check the senitivity levels move them all the way to the right the null needs to be to the left let me know if this takes care the problem if not we can do some more testing.
May 08, 2010 | Saitek Pro Flight Yoke System Flight...
Hi there I plug flight yoke into usb and get no recognition and no power even the green led on yoke does not light?? however if i plug the throttles in the light does come on on the throttle assy (small...
The yoke has effectively got a USB hub built in, and it sounds like your throttles are getting power from the hub okay, but the yoke is not. Suggest you return it for a replacement to Saitek
Mar 26, 2010 | Saitek Pro Flight Yoke System Flight...
I have Microsoft Flight Simulator X and a Satek X52 flight control, however I have problems with the throttle on all aircraft. I have to use the F-4 key - can you help?
You need to assign the throttle function correctly WITHIN FSX settings area itself. Also calibrate the joystick in windows first. If you are not familiar with assigning FSX functions to your joystick, check the Learning Center section within FSX for step-by-step details.
Feb 24, 2010 | Microsoft Flight Simulator X for Windows
MCFS Joystick Problem
Make sure, that your Joystick is compatible with the version you are having problems with. If not, make sure that it's enabled in the configuration of MCFS. If none of those work, you will most likely have to purchase a more compatible Joystick.
Matt P,
Computer/Gaming Relations Team.
Sep 16, 2009 | Microsoft SideWinder Precision Pro 2.0...
Saitek X52 Flight Control Problem
Remove the X52 and drivers from your system. You have to install them in a certain order, so look in the documentation for the correct way to install and you will be okay. Good luck
Feb 02, 2009 | Saitek Pro Flight Yoke System Flight...
Where i can find it?????
I have bought 2 sets of Saitek proflight controls ( Yoke & trottle quadran) for AUD$ 399 each.
I only need one yoke but 2 Throttles. happy to sell the second yoke ( New still in the orriginal packaging with warranty & receits -purchased yeasterday 28.1.2009) for AUD $250 + postage.
charles_loko@hotmail.com
+61 0421 035 975
Jan 13, 2009 | Saitek Pro Flight Yoke System Flight...
Combat flight simulator wont recognize my sidewinder precision 2 joystick on vista but it did on xp?
I am farmiliar with most flight simulators and know that you have to go to settings on the main menu the controls and select joystick, enable joystick and/or calibrate joystick. If this doesn't wok then in gameplay push "alt" on your keyboard if the task bar for flight simulator isn't at the top. Once or if it is allready there select settings and then enable joystick. If this doesn't work then call or contact or google microsoft flight simulator.
Jun 25, 2008 | Microsoft SideWinder Precision Pro 2.0...
IPACS Aerofly 2 Flight Simulator Logo
1,290 people viewed this question
Top IPACS Apps Experts
Marvin
Marvin
Bill Boyd
ray gallant
Are you an IPACS App Expert? Answer questions, earn points and help others
