The codes are the TV not the remote, so here are the codes I show for he Sanyo TV. You will need to just keep inputting them until one works. I would try the "Code Search" function of the RCA remote first.
Sanyo Remote codes: 0154 0208 0157 0280 0484 0292 0721 0011 0036 0045 0370 0068 0339 0072 0216 0104 0217 0145 0146 0156 0555 0381 0412 0009 0508 0544 0163 0799 0037 1154 0108 0159 0556 0486
SOURCE: code for sanyo tv phillips universal remote cl034
the code is 0506 Ihave the same remote and tv
SOURCE: sharper image universal remote
1) Turn on TV;
2) Press TV on the remote control;
3) Press and hold SETUP, until the red LED indicator blinks twice;
4) Enter 9-9-1-1 on the numeric keypad;
5) Press POWER on the remote;
6) If the TV doesn't respond, repeat #3, #4, #5.
SOURCE: RCA RCR311W Universal Remote Code for LXI TV
From what I can tell, it could be any of these codes:
1000
1006
1048
1049
1062
1072
1073
1100
1109
1130
1162
1181
1203
1212
1233
I used this website:
http://tv.rca.com/RCATV/NewTV/Templates/GenericSupport.aspx?NRMODE=Published&NRORIGINALURL=%2fen-us%2ftechnicalsupport%2ehtml&NRNODEGUID=%7bCDBA69CE-8CEA-435A-8F62-C5E6DBE1ACF6%7d&NRCACHEHINT=NoModifyGuest#
SOURCE: programing codes
Here is the link I just found the manual on for this remote control, which I needed the codes for myself: http://safemanuals.com/brand-user-guide-instructions-owner-manual/RCA go there type in the remote model RCR450 enter, click on the link that comes up and download the Manual in PDF form.
The codes for Sanyo are 1004, 1048, 1049, 1073, 1080, 1162, 1169, 1180 depending on which model you have.
OR:
1: Turn on the device you want to program ex: the TV
2:hold the button for the device you need to program in ex:TV
while holding down TV button hold down ON/OFF at the same time for 3 secs and the light should turn on and stay on.
3:click the ON/OFF button until the TV finally turns off may take many times but as long as the light stays on when your not pushing a button you still have codes to go through.
4:press the stop button and the device is programmed into the remote.
SOURCE: sanyo tv codes
lost remote for sanyo tv now have a G E universal remote and i need the code to work the tv
