SOURCE: Symbol Spark LS 1004 Problem
What do you mean? you can only scan not more than 3 times? If that so,you need to change the setting of your scanner there was a limit numbers to scan. You can check by using the manual of that scanner.
Hope you like my solution please rate me SOLVE.
Best regards,
Philip
SOURCE: sony vaio athlon 2800+ started beeping,one long beep lights flash
listen carefully to the beeps
One Long Beep, One Short Beep= motherboard problems.
One Long Beep, 2 Short Beep= video problems.
One Long Beep, 3 Short Beep= video problems.
Repeated long beeps = memory failure
continious long and short beeps = Cpu overheating
hope this helps
SOURCE: Dead T4220 - 4 beeps @ POST & blinking lock symbol, screen blank
this beeps are signal of a dead cpu or memory. Check with manufacturer to confirm diagnostics.
SOURCE: dryer works for 20 sec and then beeps 6 times and stops
http://manuals.frigidaire.com/prodinfo_pdf/Webster/134420600es.pdf
this is a web site with you manuals. check it out and see if this does not get you started.
http://www.frigidaire.com/manuals
here is another with more manuals.
http://manuals.frigidaire.com/prodinfo_pdf/Webster/134509400efs.pdf
this one reads the error codes.
Good luck.
SOURCE: unit beeps several times and gives warning symbol does not start
I have a Mitsubishi air con that has broken down like this twice because gecko's have gotten in and shorted it out. We had to have the circuits replaced at $1000 a pop. I think it can short out after a lightning storm too.
