SOURCE: unknown error message UNABLE TO INIT. printer just stopped working
press menu then start bk-copy then fourtimes arrow up. machine switches to maintenance mode. press start bk copy. what two digit error code does the display show off? Post here again
SOURCE: Error 46 Unable to Init.
No need for part necessarily
SkipperOz solution pasted below
MFC-5440CN saved from the tip!
"Unable to Clean" message - found TrickyDicky's sltn 4 for various printers.
Went into maint mode as per sltn 4 - verified error 46.
"The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed."
Keyed in 80 - stepped through the items with "down" key and located Purge Counter.
"Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero
Press the Stop/Exit key to return to the initial stage of the maintenance mode.
Press the 9 key twice to return to the standby state."
This worked brilliantly - no need to tamper with any parts of the printer. Purge Counter reset did it all. Fully functional printer.
Thanks TrickyDicky for info on verifying the error code and purge reset
SOURCE: [HELP] MY BROTHER MF-210C "UNABLE TO INIT"
Dear Guru,
I have a same problem" UNABLE TO INIT " but my printer DCP 110.
Please can help me.Thanks
SOURCE: Unable to Init. 46
Your Ink Absorber box is full. The machine cleans its print nozzles by blasting them out with ink; it collects that waste ink and pumps it into a plastic box filled with thick, felt pads. After a certain number of cleaning operations, it decides it's not safe to squirt more ink into the box and gives this Error 46. Replacing the ink absorber box and flushing box and resetting the purge counter is fairly complex. Maybe someone has instructions all typed out, but your best bet is probably to take it to a Brother tech.
SOURCE: Unable to Init - Machine error 4f
ok please try this
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
