On my Galaxy S3 phone in Gallery there are 3 albums which I would like to delete. 25/12/2015 (2) Auto Backup (136) and Profile (7). I cannot find a file or folder containing these items and cannot delete them but they are in Gallery and can be viewed individually. Answer?
SOURCE: Deleting photos
-Go to Menu
-select Get It Now (the arrow icon on the left)
-select option 3, Get Pix
-Select option 2, Pix Gallery
-Once a pic is highlighted, select Options and then 7 to Erase
SOURCE: unable to sync with Outlook
The handheld names are case sensitive. make sure your name inside the pocket mirror folder matches the name (exact case) on your handheld.
SOURCE: Transfer "assigned media" to Micro SD
YOU CAN DO THIS BY MOVING YOUR FILES FROM YOUR MOBILE TO YOUR MEM CARD. THIS FUNCTION IS AVAILABLE IN YOUR MODEL.
IF YOU CANT DO SO. JUST TRANSFER THIS FILES TO YOUR COMPUTER VIA A DATA CABLE AND THEN TRANSFER THE SAME FILES FROM COMPUTER TO MEMCARD USING A MEMORY CARD READER.
HOPE THIS WILL HELPS U.
PLS. RATE MY SOLUTION.
NICE DAY
KETAN
SOURCE: Unable to view the pictures folder
i have a problem with my sony digicam i cannot open DCIM i think have a virus but i scan in computer but also i didnt open DCIM what the sign of virus folder so i can delete
SOURCE: Weird folder/filenames that will not delete
Problem: Folders / files in USB flash drive got named with weird strange characters & those folder / files cannot be copied or deleted.
Reason: Virus infected
Solution:
1. Click on "Computer"
2. Right click on the drive that contains USB flash drive
3. Select "properties"
4. Click on "Tools"
5. Click on "Check Now"
6. Check disc options will appear on screen, put a tick mark in the box in front of Automatically fix file system errors
7. Tick mark in the box in front of Scan for & attempt recovery of bad sectors is not necessary.
8. Click on "Start"
9. Upon finishing of this task, screen will show message "Your device disc was successfully scanned" and bla bla. Close it.
10. After this process the undeletable folder in USB flash drive can be deleted by selecting it & deleting it. The contents of affected folders files cannot be recovered.
After lot of struggle I got this solution on my own by the grace of God.
Sure it will work for others too.
Thanks and regards Raju
