It's a second hand car, the fuses are okay. when i play the music from bluetooth, fm radio or aux, he won't make any noise
SOURCE: Car radio doesn't work
There is a little door between the steering wheel and door. It opens up to a little compartment that you can hold something small in. You can remove that to find the fuses. On the back side of what you removed is the "map" as to what all the fuses are for.
SOURCE: renault kangoo indicators and hazard lights have
Most common cause is a failed indicator relay. Just swap it with a known good one to confirm whether it's faulty but ensure it's correctly rated for your Kangoo.
After that, the next most common causes are more expensive: the indicator switch and the hazard light switch.
SOURCE: is aux supports pen drive in car cd player
if its an 1/8" aux input and a pen drive is usb then no.
SOURCE: I have a ten year
Anything that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input (except PHONO). Get a cable like the one described here: http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT "Phono".
SOURCE: help, need the security code for renault kangoo van
Hi Guys and Gals
I have a Radio Blaupunkt FIAT Ducato CD NS 815BP331857235560 part number 7 643 318 316
Can anyone help with the code
Thanks
