Question about Electrolux Washing Machines
My electrolux washer machine clarus control screen not showing, assist?
It is Electrolux washer machine W4600H, it stopped showing itself, assist?
    New Friend:
  • 12 Answers
Check the transformer at the back of the machine if there is an output. also check the fuse on the same transformer if its blown out. Does the cpu led light come on?
Posted on Nov 09, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: Electrolux EWF 1087 error code E60
My Electrolux washer always come up with an error code of E60, Why? can any one help
Posted on May 20, 2009
Anonymous
SOURCE: How to run tHe self cleaning cycle on electrolux
http://www.ehow.com/how_5640173_clean-electrolux-front_load-washer.html
Posted on Apr 29, 2010
Kolawole Ayede
  • 327 Answers
SOURCE: Hi, Our Electrolux EWF1083 is not spinning and ...
Hello,E20 is "A problem with water draining"
Solutions:
The drain hose may be squashed or kinked
The drain pump may be blocke.check www.serviceforce.co.uk
Thanks
Posted on May 21, 2010
torres No9
jamie bryce
  • 27 Answers
SOURCE: error codes for Electrolux front load washer EWF 1087
E40 error is door interlock faulty, could be the lock or it could be the pcb u have to test them.
Posted on Jun 25, 2010
vitalhealthc
SOURCE: electrolux ewf 1090, have an electrolux ewf1090
ewf1090 washing machine not working?
error E50 is displayed?
but no reference in manual that helps.
Posted on Jan 26, 2011
Electrolux washing machine showing error 33(no interlock). what do I do?thanks
Hey Desmond, thank you for your inquiry!
From my understanding your Electrolux washer is displaying an error code of 33. I am showing that is an invalid error code. This could be a miscommunication within your control panel. I would suggest performing a reset on your washer and you can do that by disconnecting power from it for at least ten minutes. If the reset does not help correct the issue and the error code comes back please comment back. Also, let us know your model number. You can locate the model number of the door frame of your washer. Once I have that information I would be able to assist you further. -Matt
Dec 04, 2015 | Electrolux Washing Machines
Our Electrolux EWFLS70JRR0 washer has issues with door not unlocking and then occasionally stopping mid cycle. We have been limping along by unplugging and resetting lock but starting to see more random...
Thank you for your post, friend!
Based off the information you have provided your Electrolux washer is displaying multiple issues. This sounds like a faulty control panel. You may need to disassemble your washer and test each electrical component for a proper diagnosis. This is not a simple DIY job and I would recommend seeking assistance from a professional technician for proper repairs. This will help you avoid any future issues. Hopefully this is helpful. -Matt
Mar 29, 2015 | Electrolux Washing Machines
My Electrolux washing machine is showing error codes MB Alarm E33, and UI Alarm E00. It has stopped working altogether. Door wont open and clothes are stuck in ther. I have run a diagnostic test and it...
I appreciate your post, Anonymous!
From what you have described your Electrolux washer is displaying an error code of MB, E33, and UI Alarm E00. I have been unable to locate those error codes. May I have your model number, please? With that information I will be able to assist you further. -Matt
Mar 19, 2015 | Electrolux Washing Machines
My electrolux eiflw50l washing machine wont start
Hey friend, thanks for your post!
From the information you have provided your Electrolux washer is not starting. This could be a possible issue with your control panel or door latch. If your door is not communicating that it is closed then the washer will not start. Is your washer displaying any information or error codes? If you can provide any additional information I will be able to assist you further. -Matt
Mar 15, 2015 | Electrolux Washing Machines
Electrolux Perfect steam washer has a faded lcd screen. Very hard to read at this point, can someone tell me how to order and replace it Please?
Thank you for your post, Glen Wagner!
In order to get proper replacement parts for your Electrolux washer you would need to have the model number available. I would recommend reaching out to the manufacturer, to guarantee the parts are correct. If you need assistance with installing the parts you may want to consult a professional for proper installation of replacement components. I hope this information has been beneficial. -Matt
Oct 13, 2014 | Electrolux 4.2 Cu. Ft. Front Load Washer...
I have an electrolux washer and dryer. I select the was on the panel and the washing machine begins, however will stop/freeze after a minute or two
Hey friend, thank you for your post!
I see that your Electrolux washer and dryer will pause soon after a cycle has been selected. It sounds like it could be a potential issue with your door latch assembly or door strike not fitting securely within the door latch. If both are working properly it could be a possible issue within your control panel. I would suggest seeking assistance from a profession technician to come out and properly diagnose your appliances to avoid any unnecessary part purchases. -Matt
Sep 30, 2014 | Electrolux Washing Machines
Where is the drain pump on a Electrolux front load washer
Good Morning Friend,
I understand that you want to know where the drain pump is located on your Electrolux washer, model# AWF 1435. In researching the model number you provided, I show that this was manufactured in France. I suggest contacting the manufacturer directly, for further assistance. They should be able to tell you where the drain pump is located in your appliance. Hope this is helpful.
-Best Regards-
WP
Jun 10, 2014 | Electrolux AWF 1435 Front Load Washer
E31 error code on electrolux washing machine
Good Afternoon Friend,
I understand that you are receiving an E31 error code on your Electrolux washer, model# EW1000i. In researching the model number you provided, I show that this was manufactured in the UK. For North American washers, I would suggest resetting you appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. You can try this, and if it does not work, I suggest contacting the manufacturer directly, for further assistance. They should be able to tell you what the E31 means, as well as assist in clearing it. Hope this is helpful.
-Best Regards-
Jun 08, 2014 | Electrolux EW1000i Front Load Washer
Electrolux front loader wouldn't stop filling.
change water valve sounds like its stuck open ... if not only other thing it could be is your main pcb control board ££££££
Dec 30, 2009 | Electrolux EW1000i Front Load Washer
Washing Machines Logo
1,567 people viewed this question
Top Electrolux Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Poppa Maddo
Poppa Maddo
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
