Are you letting the laminator reach operating temperature? If the ready light is on and it is not getting hot then you may have a problem with the temp. sensor. Put your hand near, but not on, the top roller to feel if it is getting hot. Don't touch the roller in case it is hot. If it is getting hot then wait for the ready light to illuminate(about 10 minutes).
Not heating the rollers.
This really can only be one of a few things, temperature and pressure, also film has to loaded correctly. Go to youtube and type in abc ultima65 film loading. The temperature where the top and bottom roller make contact should be approx 300 degrees. If both of these are correct then the actual roller pressure needs to be increased. This is done by removing the side covers and slightly tightening the 5mm allen head screws on top of each roller bearing block. Westco Laminating Svcs 405-324-6092
