I need a wiring diagram for a 1999 ESP LTD -104 Bass guitar. It has soapbar pickups and four rotary controls one being a mid control.
The reason I need this is that I have just got this guitar and the wiring has been messed up tothe extent that I don't know how to connect everything up.I don't even know if it has active pickups . Even a steer on that would be helpful thank you .
Owen Tierney.
To wire a Dean Edge bass guitar with four pots (potentiometers) and a battery, you will need to follow the wiring diagram for the specific model of your bass guitar. Here is a general overview of the wiring process:
Start by connecting the ground wires to the pots and the battery. The ground wires should be connected to the ground terminal on each pot and the negative terminal on the battery.
Next, connect the power wires to the pots and the battery. The power wires should be connected to the positive terminal on the battery and to the power terminal on each pot.
Connect the pickup wires to the pots and the output jack. The pickup wires should be connected to the pickup terminals on the pots and to the input terminals on the output jack.
Connect the control wires to the pots and the output jack. The control wires should be connected to the control terminals on the pots and to the output terminals on the output jack.
Test the wiring to make sure everything is working properly. If there are any issues with the wiring, you may need to double-check your connections or consult the wiring diagram for your specific bass guitar model.
It is recommended that you follow the wiring diagram provided by Dean or consult a qualified technician if you are not comfortable wiring the bass guitar yourself. Improper wiring can damage the guitar and potentially pose a safety hazard.
The battery should be located in the control cavity of the guitar. It is in the back of the bass. Usually 4 screws holding it on. Inside your 9v battery will be located. Good luck
two of the controls are volume, two are tone, (at least usually). the best way to use the controls is to try one at a time till you find the combination that pleases you most. I have been playing bass for 40 years and have 7 bass guitars, two with active pickups and two that acoustic electric
To adjust the pick up height on the guitar, simply turn the single screw on each side of the pickup. Clockwise to lower the pickup and counter clockwise to raise the pickup. Hope this Helps!!
the problem i analyse is 1) the wires of the volume control (it has three wires wired to the input of the amplifier) wire 2 and 3 have got shortened. 2) the field effect transistor of the preamplifier has got shortened . the fet is in built in certain guitars.3) if its wire wound volume control then it has lost grounding , that is wire no 3 has lost its grounding (usually this is associated with a hum from the amplifier
