Washing Machines Logo
Andy Bell Posted on Feb 15, 2017
Hoover dyn9144DG Door lock light flashing and no program working
1 Related Answer
tbirdfan1
Michael Thomas
  • 3056 Answers
  • Posted on Dec 10, 2013
SOURCE: hoover dyn9144dg washing machine door lock flashing wont start.....lock changed still wont start.....light still flashing
Hello the
Plesre and welcome to fixya
can i ask you a question did you unplug the machine and leave it sit for at least 1 hour
See these machines have a internal computer that stores information like any settings that are in the programed in the machine
It normally takes any where from 45 min to at least 1 hour to compete the memory loss on the computer thus resetting the computer ok
so please tell me if you did this if so there is more that we can do ok
Best regards michael
Hoover dyn9144dg washing machine door lock flashing wont start.....lock changed still wont start.....light still flashing
Hello the
Hoover nextra washing machine door wont lock / cycle start
sounds like the door lock mechanism. if this cannot signal it has engaged, to the board, no other function will work (you don't want the washer going with the door open, trust me :) )
Hoover Nextra HNWF 3135 Door Not Locking
1) since you do not have any error code, because you do not mentione, we must shure you have problem with the switch door, test for open or defective and replace, Test the wires loose, or broken wires.
God bless you
Hoover Nextra HNWF 3135 door will not lock
1) test the switch door, you do not have error code.
see the video, and replace for defective switch, or loose wires or broken, or burn.
God bless you
1helpful
Machine wont sart
Your door lock/latch is broken, this is a common issue with front loading washing machines and the only way to fix it is to replace the door switch.
Hoover dst 10146p fault
Ken did you solve this problem with the machine as mine has just started to do the same thing, thanks
17helpful
2answers
After a power cut my washer wont work the door security light just keeps flashing! Model Hoover Vision HD
Ihave a Hoover Vision HD washing machine and the "Door Security" light keeps flashing. I have looked in the manual and it says the door is not properly shut. However the door is correctly shut and as a result the machine will not operate . The door will open or close but will not start a cycle to wash. Any suggestions please????
3helpful
5answers
My Hoover Optima OPH 714 D washing machine won't start
Hope your tried switching off the machine for half to one hour, to re plug. Machine might re-set.
If helped, pl click, it could help others.
Top Hoover Washing Machines Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
