Whirlpool duet fw95hedco washer won't spin at max speed & leaves all clothes wet. No error codes during tech diagnostic visit. Washer only 18 months old. At the end of cycle, gets to 12 mins on timer, tries a few times to spin fast but never gets there & quickly shows 1 min remaining & back. shuts off. Can hear washer draining though hose Said they will order MCU but will be another WEEK. Is that going to fix it? Saw another site say the "stator" needs to be replaced. Can't go weeks without washer in this house.
I have found it is an unbalance condition, it doesn't dry your clothes. The fIx I found is to add 3 or 4 clean bath towels to your washer. The more the better if you are washing a king size blanket. Then select Rinse/Drain & Spin then push extra rinse to turn out light. Then start the machine. Always works for me.
Model number you listed is not correct. The stator is more time consuming to replace and if this is a warranty repair then it is cost effective to replace the motor control first.
Possible Defective washer transmission. Do you overload the washer with heavy items like towels or blue jeans very often? That can cause early failure.
Testimonial: "I would have to day that I never OVERload it but wash towels & bedding every week with a family of 5. Out of curiosity, what kind of problem would it point to if the fast spin worked on the Cold Wash specific setting only? Not the water temp, but the cycle setting of the first dial?"
