SOURCE: roper washer top loader spins very slow
if the appliance has a induction type motor could be that the running capacitor is failing coul be the motor itself
SOURCE: changing a belt on roper top load washer
There is no belt on a roper. It called a drive coupler. its direct drive. Go to sears online and go to the parts section and put in your model number. Look at the diagrams and it will show you where it is located (easier to show you than to tell you.)
SOURCE: Roper top loading washer not spinning or agitating
Hi
If your washer pumps out the water but doesn't spin, check these:
If your washer doesn't agitate, check these:
Lid switch
If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler
Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts
Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Drive motor
Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys
The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission
The transmission could have either of these problems:
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator
The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
SOURCE: I have a top load Roper washer that won't spin.Any ideas?
That sounds like a bad drum bearing, check and eventually replace the drum bearing.
SOURCE: Roper top load washer spins but does not drain
replace coupler for direct drive whirlpool washer yes roper is a whirlpool washer #part number 285753 you can watch video on youtube to replace
