Lasers do not bend, per se. If you have some sort of distortion of the beam, then the reflector is faulty or damaged. If the beam is slanted then the gimble assembly is not hanging straight.
In either case these are throw away units. Go back to the retailer and see if they have a solution. Or call Black and Decker and see if they will replace it for you.
SOURCE: PLS2 laser level, horizontal line very dim, vertical line ok.
PLS 2 Palm laser; dim horizontal line. vertical line OK
SOURCE: DEWALT LASER LEVEL SELF LEVELING THE LIGHT LASER
Laser diodes are no like light bulbs. When a light bulb burns out, it goes black. When a laser diode burns out, it goes to an extreme low power state. You can see red at the source, but there is no beam to speak of. If this is what you're seeing, then contact Dewalt. They are low quality instruments, but will try there best to get you a new one, at a reasonable price.
SOURCE: how do i change spring contacts on dewalt 087 laser
Are there spareparts in US for this DW087 ?
In Europe there are spareparts for to get !
Its for Milwaukee in Europe that there are little Milwaukee tools where nothing is to get but in australia all parts and may be in the states to.
All based on marketing technical decisions and differences.
Laser's do fail, and that is what is going on here.
Hi Michael Moore, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? bends how?
The line is like a big arc, as if the light is going through a prism.
