I had the same problem, but solved it. You have to connect your printer SP210 to your computer. Search (in Windows) "Smart Organising Monitor Status" Select Printer (new dialog box) Click OK (see the error code SC545) Click on User Tools Printer Configuration (Access Code is Admin074) Find Fuser SC Reset under Maintanance Click Ok Close Restart your printer Your problem is solved now
OR
Without connecting your printer to Computer (you can do this):
Turn on the printer Press C (Red colour centre) button once Enter 107 (nothing will be shown) Press the Green (Coping) button for 5 seconds See the Display --> Select Engine Maintenance Select Ok Select Fuse SC Reset (press down arrow - at down you will find it) Execute (by Pressing the Down Arrow) Done Restart your printer. Your problem should be solved....
It means, there is a paper jam. Delete the print jobs in the computer's print queue or disconnect the communication cable (USB or LAN). This is to stop the printer trying to execute print commands. Turn off the printer. Pull the paper drawer and check for a stuck sheet. Remove carefully if any. Open front and rear covers, pull out the toner cartridge and inspect for stuck paper in the paper path. Remove if any. Close the covers, put back the paper drawer and turn on the printer. See if the red light is gone. If not, there still may be some piece of paper or misplaced/broken sensor. If looks normal, reconnect the cable/try printing again and listen if the printer tries to pick up paper. If yes, but red light comes again, then the pick-up roller needs cleaning/replacing. If not, check if the paper size in your document matches the one loaded and set up in the printer. The printer may be waiting for different paper size.
might be fuser is bad repair or replace then reset code. To reset this error try the code:
"Clear Mode"+107+"Clear/Stop" hold for 5s.
Turn ON and OFF the Main Switch.
The cable pulleys will be behind something in each corner of the camper , you will need to remove the wall somehow at the bottom corner , sometimes depending on the model it is easier to remove the outside panel and put the cable back on the pulley then put the outside panel back on , be prepared to damage it though as they can be very stubborn to remove but you can repair it later .
