Tablets & eReaders Logo
B
Brian lee Posted on Feb 19, 2017
I hav the small acer which has a hdmi port .I would like to get the 10 inch iconia.Does it have a hdmi port?
1 Related Answer
adminmax62926
Max Desrosiers
  • 21 Answers
  • Posted on Dec 31, 2016
SOURCE: I want to know how to change the fonts on my Acer Iconia 10 B3-A30 tablet.
You cannot change the font on your system but you can change the fonts in individual applications such as browsers or ebook reading applications
How do I find my SSID number on Acer Iconia One 7
The SSID number is the identity of the router you are trying to connect to, not your computer.
Turn on the Wi-Fi under settings and look at the list of SSID's there.
2helpful
How would I connect my acer a1 830 to to my tv to watch showbox ... I was told i could use a micro usb to HDMI adapter to do this and cannot figure it out....
No, the A1-830 doesn't support MHL (micro-USB to HDMI). So the micro-USB to HDMI adapter will not work. The tablet's USB port will only support connecting to the charger or a PC's USB port. Here's a list of known MHL devices: http://www.mhlconsortium.org/devices.aspx . The previous model (A1-810) had a micro-HDMI port that could connect to a TV's HDMI port with the appropriate cable. You might be able to use the AllCast app and a Roku or FireTV box. You will need to upgrade to the Premium version for any files longer than 5 minutes.
The other way to mirror content from the Iconia A1-830 would be to transfer it to your computer. Then send the file to the TV via Plex or SmartShare depending on the file and your TV. If you can upgrade the tablet to Android 4.4.2 or higher, then a ChromeCast will let you mirror content directly from the Iconia A1-830. This will require steps that can make the tablet unusable (research rooting an Android device).
I wish that I had better news for you. Unfortunately, even if you have a TV with a USB port, it probably will not access the files on the tablet. (Many only support FAT32 or NTSC file systems.)
1helpful
How do I repair the USB PORT on a ACER ICONIA B1.
Step 1 - Back Case
  • To start, gently separate one corner of the case using the black spudger.
Step 2
  • Once you have successfully pried the spudger in between the front case and back case, continue do so around the entire tablet until the back case is completely disconnected.
Step 3 - Battery
  • Remove the 5mm screws that are securing the battery to the rest of the tablet.
    • Use the Phillips #00 Screwdriver to remove the 5mm screws.
Step 4 ¶
  • Use the sharper end of the spudger to disconnect the battery from the mother board.
    • The battery connector will slide off.
Step 5 - USB Port
  • After setting aside the battery, remove the two 5mm screws holding the metal plate over the USB port.
Step 6
  • Find and remove the silver 5mm screw holding down the metal cover opposite the USB port.
Step 7
  • Disconnect the blue cable by gently lifting the flap.
  • Remove the indicated 2mm screw holding the speaker in place.
Step 8
  • Pull up the metal panel just enough to allow access, then remove the USB port.
How can i connect my tablet
Just going to go through steps.
1. mIni hdmi to to tablet
2. hdmi on other end of cable to a hdmi input on tv.
3. go to input on tv and change input where you plugged in hdmi.
4. start your tablet. what ever is on your tablet will now show up on tv. (home screen, movies, e-mail, etc.)
Just a reminder, you have to switch input on tv each time.
GOOD LUCK
How do i hook up my acer a1 iconia to hdmi tv
make sure you have changed input on tv to the hdmi you plugged the cable into.
Acer iconi b1 thermal warning
why does my acer iconia keep saying Thermal warning and shutting down when I have only just switched it on?
Top Acer Tablets & eReaders Experts
NOEL
NOEL
Are you an Acer Tablet and eReader Expert? Answer questions, earn points and help others
