Cell Phones Logo
N
Naomi rhode Posted on Feb 21, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can no longer access My IPHONE7 speaker for dictating??
sheva420
Level 2:
  • Expert 46 Answers
  • Posted on Oct 11, 2019
sheva420
Expert
Level 2:
Answers
46
Questions
0
Helped
10822
Points
103
Try a hard reset if not it may be a hardware issue
Should I get my iPhone7 speaker replaced from different repair store?
if its out of warranties i would go for the store that offers you the best price and garanties after the repair.
Apr 14, 2018 • Cell Phones
2answers
Where to send pocket mmo recorder for repair?
Roach Reid Office Systems 2737 Gilchrist rd Akron Ohio 44305 ATTN Mark
The philips LFH9600 dictations are going back to the beginning
There is a minus and plus button under the menu button. If she rests her thumb on the minus button it will skip backwards. This will also cause lost dictation because it will skip back without knowing about it and you can dictate over what is there.
2answers
What is a dictation system?
Wikipedia: Digital dictation is a method of recording and editing the spoken word in real-time. The recording is done by the use of a digital recorder. Digital recorders are lighter have a longer battery life and are able to record a for a lot longer utilizing the same media, as compared to analog tape based dictation machines. The files generated with digital recorders vary in size(kilo bites or mega bites) depending on the manufacturer and the format the user chooses. The most common file formats that digital recorders generate have following extension WAV, WMA, and MP3 true dictation machines record in the DSS and DS2 format.
1helpful
We have installed Dragon Medical 10.0 on a computer that is accessed by multiple users at our clinic. When I log on to the computer and try to access these accounts I get an error that reads "User...
Yes, it's probably because you don't have administrator rights on the system. If you can't be given them, another option would be to have the doctors save the dictations somewhere other than their user directories, like a new folder on the C drive called 'Dictations' or 'Shared Files' or some thing similar.
Good luck.
When the portable dictation machine is turned on, it reads memory access error 2003, 1001, and i cannot dictate or do anything with the machine.
Press the 'OK' button, then it'll prompt you to 'Save All Data To PC'. If you have dictation on the portable that you want to save, connect it to the PC and hit 'OK'. It'll go into 'PC Operation Mode' and you can transfer your dictation like you normally would. Then when you disconnect and reboot the portable, you should get the error again.
To clear the error, press 'OK' again, but on the 'Save All Data To PC' screen, instead of pressing 'OK', press 'Esc' (I think that's the other option - this is from memory!) and it'll prompt you to delete the data. Press 'OK' and it'll format the memory and reboot - then you should be good to go.
MY DRAGON NATURALLY SPEAKING 10-PROFESSIONAL DOES NOT WORK IN AOL EMAIL. IT WORKS WITH EVERY OTHER PROGRAM. BUT, WHEN I TRY TO DICTATE IN AOL EMAIL, NOTHING HAPPENS. ANYONE KNOW OF A SOLUTION?
Dragon Naturally Speaking 10 has not been tested to work with web based e-mail. It's also the same thing with Dragon Naturally Speaking 11 regardless of any version. As a work around and fix for this, if you want to use it through on any web based e-mail is to use the Dictation box.
Here are the simple steps to access the Dictation box:
1.Make sure you have successfully loaded a working user profile. 2.On the dragon bar, go to tools and then go to "Dictation Box" 3.Here, you can start dictating e-mail messages and use the "Transfer" button to transfer text in AOL E-mail.
I hope this solves your current problem.
Unable to understand how to dictate and play back
It may seem too obvious, but make sure the volume control is turned up fully. If you do not hear a click through the loudspeaker when pressing the record button then either the 'speaker wire has broken or the 'speaker itself is dead. Parts are still available.
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
