Re: 55 inch Samsung smart tv. Has two purple spots...
If you wish to get more details visit the site linked here. Faults and possible causes of both LCD and plasma TV screens are given with illustrations. http://electronicshelponline.blogspot.com/
It sounds like you may be experiencing issues with the LED lights that you installed in your Samsung 55-inch smart TV. The fact that the dark spot on the screen has moved to the left side and the lights are appearing at the bottom of the screen like Christmas tree lights is not normal behavior and could be caused by a number of factors.
Some potential causes for the issue could include:
Incorrect installation: If the LED lights were not installed correctly, it could cause the issues you are experiencing. Make sure that the lights were installed according to the instructions provided by the manufacturer and the video you watched on YouTube.
Damaged LED lights: The LED lights themselves may be damaged or malfunctioning, causing the issues you are experiencing. Try replacing the LED lights with a new set to see if this fixes the problem.
Other issues with the TV: The issue could also be caused by a problem with the TV itself, such as a malfunctioning display or control board.
To troubleshoot the issue, you can try the steps listed above. If you are unable to fix the problem, it is recommended to contact Shop Jimmy or a TV repair technician for further assistance. They will have the necessary tools and expertise to properly diagnose and repair the issue.
The screen and the LCD are broken and are going bad and should be replaced for your TV and the ribbon might also be damaged too and needing to be replaced.
If your screen is purple, this indicates that your HDMI cable has a poor connection. First, try reinserting the HDMI. Second, try replacing it. Also, try a different HDMI input.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to both LCD & Plasma TV screen are given with illustrations. You can get an idea about the fault to an extent.
Could be a power supply problem or a moister problem with connections.
I would remove the back panel and inspect the power supply for bulging capacitors, blow the unit out and run a hair dryer around the outside of lcd screen.
