SOURCE: "wrong size paper"
Change the cofiguration of the size in your fax machine see if accepts them then
SOURCE: printing blank papers
I've tried everything before for months... unplugging, new cartridges, servicing, etc. I've always avoided jarring an electronic item, but hitting the front fixed it! A couple of open-palmed smacks above the paper drawer, and it printed this very page. Apparently, sometimes the cover over the laser sticks shut after replacing the print cartridge, or removing a paper jam. Sounds crazy, but smack it!
SOURCE: Scale from legal to letter
Legal size is 11x17 inches and you cannot get a legal length document when selected for landscape.
Landscape means that it is 11 inches high and 17 inches wide.
You need to set it to letter and select 11x17 inches.
SOURCE: CANON MF4140 'LOAD CORRECT PAPER CASSETTE : LTR'
I had same thing happen after a fresh Windows install. It was hard to figure out since it had been working fine until then, but luckily it is simple to fix. Open the Start Menu > Settings > Printers and Faxes folder. Then right-click on the Canon MF4100 Series printer and choose Printing Preferences. In there, change the Paper Size to Letter (instead of A4). You may also have to do this in the Print setup for whatever program you're using to print.
I had the same cr@p of the problem yesterday. The problem was not in
the paper. You have to do 2 simple things, from which one will solve
the problem.
first, download the latest drivers and install them.
And the more important thing, the problem occurred due to incorrect
paper format. Solution is very simple. Open MS word or something
similar, file->print.. and before you print open Properties menu.
There for the Output Size will be selected "Match Page Size". you don't
want that (i don't know why it doesn't work), but the solution is
manually select A4, or whatever your page size is.
