One For All URC4220 Remote Control Logo
Posted on Jul 23, 2009
Tv codes +one for all remote control +URC-4220 +JVC Av-20120 TV
Anonymous
Level 1:
Problem Solver:
  • Contributor 15 Answers
  • Posted on Sep 16, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
15
Questions
Helped
5949
Points
42
Hi, the codes I have for JVC TV's are as follows: -
027, 051, 068 & 081
Try them & see how you get on.
Cheers
Shaun
Need a code for a urc-4220 control to operate a sanyo tv
Hello
Setup code for Sanyo TV with One For All URC-4220 remote control is:
0154
OK.
tip
One For All URC-4220 Code Search
One For All URC-4220 Universal Remote Code Search
To program your One For All URC-4220 universal remote control to operate your TV, the remote has a code search function.
To search for a code for your TV:
  1. On the remote control, press TV once.
  2. Press and hold SET until the LED blinks twice, then release SET.
  3. Enter 9 - 9 - 1.The LED will blink twice.
  4. Aim the remote control at the the TV and slowly alternate between pressing POWER and TV. Stop when the TV turns off.
  5. To lock in the code, press and hold SET until the LED blinks twice, then release SET.
I hope that helps.
___________________________________
One For All URC-4220 Manual
One For All URC-4220 Code List
One For All URC-4220 Code Entry
One For All URC-4220 Reassign Key
on May 30, 2010 • Televison & Video
tip
One For All URC-4220 Code Entry To program your One For All URC-4220 remote...
To program your One For All URC-4220 remote control to operate your TV you can use the direct code entry function.
To enter for a code for your TV follow these steps:
  1. Turn on your TV.
  2. On the remote, press the TV key once.
  3. Press and hold SET until the LED blinks twice, then release SET.
  4. Enter the first four-digit code from the code list. The LED will blink twice. If it does not blink twice, go back to step 2 and try the same code again.
  5. Aim the remote at the TV and press POWER. The device should turn off. If it does not turn off, repeat steps 2 through 5 with the next code in the list.
I hope that helps.
____________________________________
I need step by step instructions to program the codes into my One For All universal remote URC-4220 to my JVC tv.
The code for a JVC TV is 0053 (non-combination TV). To program the remote, turn on the tv manually. Then press the TV button once. Then press and hold Set until the LED blinks twice. Then release Set. Aim the remote at the TV and enter the four digit code. The LED should blink twice again. Press the power button on the remote. The TV should turn off. Turn it back on and check if the remote does the other functions that it should for the TV.
There is a manual code search option. Press TV once, then press and hold Set until the LED blinks twice. Release Set and enter 9 - 9 - 1 . Then aim the remote at the TV and alternate between pressing Power and TV. When the TV turns off, press Set to save the code. Turn the TV back on and check if the remote performs other functions. If not, repeat the above steps until another code turns off the TV.
The manuals for All-for-One Remotes are available here: http://www.oneforall.com/support/manual . Choose universal remote control in the top drop down and then the URC-4220 in the second.
Please note that universal remotes only have codes for devices released 6 months of more before the remote was programmed. If your TV is newer than your TV, then you may need a newer remote.
I hope this helps.
tip
I hope that helps.
tip
  1. Turn on your TV.
I hope that helps.
9helpful
7answers
One for all URC4220
go to one for all universal remotes
5helpful
3answers
I can't program my remote. It is a One For All URC-4220
http://www.ofausa.com/list_codes.php?db_value=access4&remote_choice=URC4220
see codes there
2helpful
3answers
URC-3220
JVC SETUP CODE IS OO53FROMURC-3220
Top One For All Televison & Video Experts
ExpressFiX
ExpressFiX
ZJ Limited
ZJ Limited
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
