Televison & Video Logo
Thando Bacela Posted on Feb 24, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello my sansui TV model SV-3221 LCD responds when I switch it on but the screen is black and the red light inside the TV is flashing.
Gustavo Ortiz
Level 3:
  • Master 637 Answers
  • Posted on Apr 16, 2020
Gustavo Ortiz
Master
Level 3:
Answers
637
Questions
8
Helped
314186
Points
1811
5 Related Answers
maatmartin7
matt martin
  • 1259 Answers
  • Posted on Jan 10, 2010
SOURCE: Hi there I have a Sansui LCD model sv-46lcd tv
The signal boards will do this and is a common problem for this set!
duane_wong
Duane Wong
  • 6826 Answers
  • Posted on Jul 14, 2010
SOURCE: Hello have a problem with tv Model is: lg
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6281
The above link goes to lg's website describing the red flashing light where the power switch is, and
another switch down below which can turn that light off.
Try switching that other switch below off so the light turns off. Then, switch it back on.
If that doesn't work, then service should be scheduled for this discontinued model.
Hope this helps on your lg tv.
Chi Chu
  • 8457 Answers
  • Posted on Oct 03, 2011
SOURCE: Picture shows for 1 sec when switching on TV, and
Now u turn on the tv the tv pictures only flashes a few sec.than dies,but the tv still have audio sound left only?Yes,mean ur tv have a 1 or 2 long boards that are call a LCD inverter boards are the causes and the problems.These 1 or 2 long LCD inverter boards only job are to provided the tv LCD screen panel for a backlight for the tv to have picture only.Tries websites like Shopjimmy.com,Ebay.com to buy a 1 or 2 the tv long LCD inverter boards for the replacement.
gopakumarg43
  • 76851 Answers
  • Posted on Dec 08, 2012
SOURCE: Vertical black stripe accross screen
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there or do a search by type in the Brand Name of your device in the Search Box, at the top right of the display window.
gopakumarg43
  • 76851 Answers
  • Posted on Dec 09, 2012
SOURCE: sony lcd tv black screen 3 flashing red light model kdl32s2010 can not reset
Over Voltage Protection 03
Check the site linked below. As stated above, three blinks are the symptom of over voltage. If an over voltage comes out of the secondary side of the SMPS power board inside, this type of indication will occur. You have to troubleshoot and repair the main power supply regulator board. In most cases, it might need replacement, as components to this board are not easily available in the open electronic spare part market.
Blinking codes, and fault finding are described in detail here.
Hi, I have a Sansui SV-4210 LCD HDMI TV . It does not switch on with the remote and only works once I unplugged the power cable and plug it back again. Lately it occurs every time and I have to do th
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Sansui sv
Flashing of standby light indicates the fault. From the number of blinks that occurs at one time switch on, you can get an idea about the faulty circuit section inside. The blinks are called blinking codes. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. More than Nine Lakh viewers cannot be wrong. Blinking codes to many brand TVs are give in detail. Pull up older posts there.http://electronicshelponline.blogspot.com/
2answers
Picture shows for 1 sec when switching on TV, and then screen goes black on my Sansui TFT SV-2010 LCD Monitor
I have a sanyo remote and a sansui tv how do i program the tv
Hello
I don't have a code for Sansui TV to be programmed with Sanyo remote control But hava a philips Universal remote model which can be programmed for Sanyo TV and has its codes.
Remote Model ===> Philips CL 034 Universal Remote Controller.
Codes
0115 0632
And herealong with I sends some universal remote codes, that you can check it for.
Four Digit Universal remote code for Sansui TV are
0135 0310
Three digit universal remote code for Sansui TV are
135/ 136
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
30helpful
7answers
Unlock childlock sansui sv-t21pa2s
hi
how to open child lock for this sansui tv
Top Sansui Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
