Optics Logo
D
Duane Northrop Posted on Feb 25, 2017
I have a Winchester Model 12 20 gauge made in 1912 [serial #3138] but it has a 23 inch barrel marked cyl bore. It does not appear to be cut down. Would this have been a special ordered gun?
5 Related Answers
bigcass
Josh
  • 35 Answers
  • Posted on Oct 19, 2009
SOURCE: I have a vintage model winchester 24 12 gauge SxS
I spent that past 20min or so runnin through the normal places I normally find Owners manuals for older guns with no luck.
The only place i was able to find one is on ebay. Gun Broker.com is also another place they are sellin them.
Here is a LINK to the ebay Auction.
KingDWS
Dave King
  • 1606 Answers
  • Posted on Mar 24, 2010
SOURCE: Winchester 12 ga defender mod 1300 mfg. date
I think you might have better luck contacting winchester support or one of the bigger gun stores or even an online gun forum as this isn't quite a spotting scope question ;-]
http://www.winchesterguns.com/customerservice/index.asp
They should be able to tell you if the barrel is available and maybe how much or what dealer has one.
The 1300 was made from 1978 to 2006 so that should narrow down the date at least.
Testimonial: "I appreciate the information, some mentioned th "L" in front of the S/N designationing something but I dont recall thanks Dizzie78"
Anonymous
  • 155 Answers
  • Posted on Sep 14, 2010
SOURCE: Im trying to ask this question but your service
Hi lje70. FixYa actually does not have a dedicated firearms category, which is why you were unable to find an appropriate category to post. As your question is currently filed under "FixYa" it won't be shown to the best Experts.
I recommend posting your question again. Make sure that you do not click "Get Immediate Assistance". On the page where you enter your question details/product, click the link that says you can't find your product. Then, choose "Camera, Camcorders, & Accessories" in the first column, and either "Rangefinders" or "Spotting Scopes" in the second column. These are the only firearm-related categories on our site, and will give you the best chances of meeting up with an Expert that can answer your question.
Thanks for using FixYa!
Lauren
FixYa Community Manager
Norman Worley
  • 1273 Answers
  • Posted on Jan 03, 2011
SOURCE: Hi i was wondering if
take a look at http://www.gunsinternational.com/Winchester-Model-1886-Rifles.cfm?cat_id=501&start_row=51
and other sites and you can just about make your own estimate
Anonymous
  • 10865 Answers
  • Posted on Jun 06, 2011
SOURCE: what is a Winchester model
hello big.......... Although most of these sell in the 600-700 dollar range, a few of the fanciest models sell for upwards of 2000. here is an excellent link to help you determine which version of the model 94 you have. http://www.winchesterguns.com/library/pressreleases/detail.asp?id=219
Joe
1helpful
Anything you can tell me about Winchester Model 97 Ser# 201413. when it was made and value.
The Winchester Model 1897 evolved from the Winchester Model 1893. The Model 1897 and 1893 were both designed by John Browning. The Model 1897 is an external hammer shotgun lacking a trigger disconnector. This means that the user can hold the trigger down while cycling the shotgun and once the action is returned to battery the gun fires. The gun itself is classified as a slide action pump shotgun. It was the first truly successful pump-action shotgun produced. Throughout the time period the Model 1897 was in production, over a million of the type were produced in various grades and barrel lengths. 16-gauge guns had a standard barrel length of 28 inches, while 12-gauge guns were furnished with 30-inch length barrels. Special length barrels could be ordered in lengths as short as 20 inches, and as long as 36 inches. Along with various grades and barrel lengths, the Model 1897 came in two different chamberings. One was the 12 gauge and the other was the 16 gauge. The shells should be of the 2-¾ inch or 2-? inch model. Any shells larger are not recommended. An average Model 1897 held 5 shotgun shells in the magazine tube. After including the one shell that could be held in the chamber, the average Model 1897 held a total of 6 shotgun shells. However, this would vary from grade to grade. When working the action of the Model 1897 the forend (fore grip) is pulled back, forcing the breech bolt to the rear which extracts and then ejects the spent shell while simultaneously cocking the external hammer by pushing it to the rear. When the forend is slid forward again, the breech bolt pushes a fresh shell into the gun's chamber and locks into place. This action of sliding the forend back and forth (pumping) is why the gun is classified as a slide action (or pump) gun.
2answers
What is the value of my model 94 Winchester 30 30 serial 2444852 also aprox age
It looks like years between 1959-1960 Good luck on price. That will range based on condition.
1helpful
Trying to find year and manufacturer of a single shot 410 breakover shotgun. Serial number L5972 has serated area by notched site.
iver johnson single barrel champion shotguns with a single letter suffix to the serial number were manufactured between 1920 and 1929. it seem that most of the 410 were used quite a bit and very few are in excellent condition. the original finish was an oil finished stock, browned barrel and case hardened frame.
CHAMPION MODEL 36--------------------------------1909-1922
Single barrel; rebounding center mounted hammer; top lever operated break open design; gauges: 12, 16, and 20; barrel length: 28, 30, and 32 inches (features barrel and lug forged in one piece) bored full chock only; American black Walnut but* stock and fore-end; automatic extractors; weight 6¾ pounds; overall length with 30 inch barrel 45 inches; case hardened receiver (nickel available as option), browned barrel; automatic ejectors extra cost option; .410 bore, 24 and 28 gauges offered in 1913; 24 gauge dropped 1928; all gauges except 12 dropped after 1941; name changed to Champion single Barrel in 1917.
CHAMPION SINGLE BARREL---------------------------1923-1978
This is the same gun as the earlier Model 36 champion except that the smaller gauges are now built on the same frame as the large gagues. See above picture for specifications. The exact year production stopped has not yet been determined. Some of these single barrel shotguns have been seen with Canadian marking, these were most likely shipped to Canada and then marked as there is no evidence that Iver Johnson's Arms & Cycle Works ever had a manufacturing factory in Canada
Jun 01, 2015 • Optics
1helpful
How old to the date is a Winchester Model 12 12 gauge shotgun with serial # 80799 ?
Your model 12 was made sometime in 1915 probably early first quarter as Winchester site states that 1914 ended with serial no 79765 for the model 12
Mar 15, 2015 • Optics
How to build a silencer for
Try YouTube as there are some excellent videos on silencer manufacturing
Most important thing is to get the barrel screw cut correctly to the bore not the barrel
When was my winchester model 12 16ga shotgun serial#787927 manfactured?
Nicknamed, the Perfect Repeater at its introduction, this shotgun se tthe standard for pump action shotguns throughout its fifty one (51) year high rate manufacture and production life. From 1912 until the shotgun was first discontinued by Winchester in 1963, nearly two million Model 12 shotguns were manufactured and produced in various barrel lengths and grades. Initially the M12 was chambered strictly for 20 gauge, however 12 and 16 gauge versions came out in or around 1914, and the 28 gauge version of the Winchester Model 12 came out in 1934. A .410 version was never produced; instead, a stripped down variation of the Model 12, commonly known as the Model 42, was derived directly from scaled drawings of the model 12 and produced instead. The year of manufacture for serial number 787927 is 1939. hope this helps! im pretty sure that this is right. check it out on the web.
Top Winchester Optics Experts
ADMIN Andrew
ADMIN Andrew
 Mikey
Mikey
Thomas Perkins
Thomas Perkins
Are you a Winchester Optic Expert? Answer questions, earn points and help others
