Televison & Video Logo
Patricia Tang Posted on Feb 26, 2017
Westinghouse tv Model:Sk-32H540S, we got it from action, but we dont now the PIM#, how can we reactivate it?
5 Related Answers
Anonymous
  • Posted on Jan 27, 2009
SOURCE: Westinghouse SK-32H540S LCD TV Turns Itself On - Appears Random
turn the timer off.
Anonymous
  • 120 Answers
  • Posted on Feb 03, 2010
SOURCE: Westinghouse SK 32H540S Turn on TV, get
Hello, it sounds like you need to replace the inverter board, I believe this model has LIPS board which is the power board and the inverter board put in to one single board. You can find price and availability for parts by emailing [email protected].
Anonymous
  • 16 Answers
  • Posted on Mar 23, 2010
SOURCE: TV Turns on picture comes on for 30 seconds then
This is not the fix for this TV. I guarantee that none of the capacitors exhibit the common bulging characteristics of a faulty capacitor. The common answers to everyone's questions are to replace the capacitors. Most likely the culprit is the inverter board.
Anonymous
  • 120 Answers
  • Posted on Apr 07, 2010
SOURCE: Westinghouse sk-32h540s TV, VGA input, image can't center.
Hello, two things, one try using the TV with the native resolution of 1366 X 768, and secondly try updating your video card. If you are not having this issue with the TV on the other inputs than most likely it is a settings issue with the laptop. Please rate this comment if it was helpful.
Anonymous
  • 3 Answers
  • Posted on Jun 12, 2010
SOURCE: Westinghouse SK 32H540S when i Turn on TV, get
The problem is cause by the transformer on LIPS inverter (Power supply + Inverter board). You could see an obvious burn on the 1 of these transformers ( There are total 3 black transformer on this board). The part number is 4302H. It is available online at http://www.lcdparts.net/TransformerDetail3D.aspx?ProductID=2775
3helpful
My Westinghouse SK-32H540S TV comes on for about 5-10 seconds, then the picture goes off. The sound continues.
You need to replaced your Inverter Board, If you can do the job, get the Board Part number and order it from Westinghouse. If not call a Professional TV Technician. At least you have an idea what's the trouble with your set. Hope this Tip will help you.Thanks
Westinghouse SK-32H540S LCD HDTV Video Comes On,
Take a strong light and put it up against the screen. Do you see a faint image? if yes, then your backlight has failed. Could be a lamp, inverter or power supply issue. Not for DIY'ers.
2helpful
6helpful
2answers
TV Turns on picture comes on for 30 seconds then picture goes off and sound stays on. Even after leaving tv on the sound stays but the picture does not come back on. Its a westinghouse SK-32H540S
2helpful
Westinghouse SK 32H540S Turn on TV, get Westinghouse logo, picuture turn on for 10 sec then black screen.
Top Westinghouse Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
