Freezers Logo
S
Sheila Penna Posted on Feb 26, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Hotpoint freezer FZ150 red light keeps flashing. I turn freezer off then on again and its ok for a bit, then it flashes red again,
Ken Wieczorek
Level 2:
Sergeant:
  • Hotpoint Expert 451 Answers
  • Posted on Mar 02, 2017
Ken Wieczorek
Hotpoint Expert
Level 2:
Sergeant:
Answers
451
Questions
0
Helped
228189
Points
825
The flashing maybe door is not sealing check gaskets on door for folds or tears or door not aligned right
Having restarted my upright Freezer how long will it take for the flashing red light to stop flashing
what was the reason for the trouble code --if problem not fixed trouble light will keep flashing if light flashing due to temp when setting is reached will stop
My hotpoint ff187 fridge/freezer is making a beeping sound and has flashing lights. We have tried everything from turning off this button and that, then trying the power off and backwards again. There is...
clean the door rubbers and sides this sometimes fixes the problem as the seals are not closing properly and the fridge freezer thinks you have left the door open.
I have a hotpoint freezer which is self defrosting but its icing up and warning message keeps flashing up
There is defrost timer, that will shut off the freezer and turn on a heating element that quickly defrosts the cooling fins. then it cycles back on. If any part of that system goes out the freezer will not defrost.
Miele F7131 S The red alarm and the orange -32 degrees orange light on the front of my under counter freezer keep flashing. I have defrosted it. It appears cold but the lights will not stop flashing.
Freezer Temp. shoud be 0 to -5 Deg. if to warm it will set off the alarm. try unpluging or turn off power to freezer for 1 or 2 min. to see if it will reset.
May 17, 2010 • Freezers
3helpful
The red warning light (exclamation Mark) is on?
check the condensor fan if it has one
Apr 10, 2010 • Freezers
2helpful
Red light flashing
red light flashing means temp. is too high (not freezing) just an indicator to let you know that there is a problem
let me know: the freezer temp. (use a temp. reader)
any unusal ice build up on the back freezer panel?
is the freezer fan running?
compressor running?
parital frozen foods?
need to know so i can help you
26helpful
Flashing red light
red light flashing on servis fridge freezer
Mar 19, 2009 • Freezers
9helpful
2answers
My hotpoint ff187e fridge/freezer keeps bleeping and flashing how can i fix this? it is only 18 months old.
Turn the second knob at the top to off (freezer knob) turn the fridge freezer off. Then turn it back on. That may sort it. Or you may need to totally defrost the machine as there could be some ice blocking some vents. May need to remove the back panel of the freezer for this (inside).
Jan 31, 2009 • Freezers
3helpful
Fridge freezer lights flashing
the flashing red light indicates a cooling problem,you should call honest local appliance repair shop(not sears they rob you blind)one other thing to try is to unplug for 5 minutes then plug back in and see if it reset sets itself,could be just a board reset issue,let me know-mike
Jun 10, 2008 • Freezers
Top Hotpoint Freezers Experts
ADMIN Andrew
ADMIN Andrew
Thomas Perkins
Thomas Perkins
Stan Ford
Are you a Hotpoint Freezer Expert? Answer questions, earn points and help others
