Replaced the power supply/backlight inverter board and T-con boards on my Samsung 37" TV
Seems worse than before
I recently replaced the power supply/backlight inverter board on my Samsung 37" TV thinking that would fix the washed out, almost white picture. The board didn't change anything, so I put the original board back in.
I read that the T-con board was the issue, so I replaced it. Not only do I not even have the white screen, but I don't have any picture at all, and the red light on the front just flashes.
Any help is GREATLY appreciated!
Thanks, Shaun. I hope I can return the T-con board I bought. I'm wondering if it's faulty since I had a (bad) picture before but now I have nothing PLUS the flashing light that wasn't flashing before. :(Thanks, Shaun. I hope I can return the T-con board I bought. I'm wondering if it's faulty since I had a (bad) picture before but now I have nothing PLUS the flashing light that wasn't flashing before. :(
You can't post conmments that contain an email address.
If you have replaced the main board and power supply board and are still getting a uniform blue screen on your Samsung LED TV, it could indicate one of the following issues:
T-Con Board: The T-Con board, or Timing Control Board, is responsible for managing the flow of video data from the main board to the LCD panel. If the T-Con board is damaged or not functioning properly, it can result in a blue screen.
Backlight Inverter: The backlight inverter is responsible for powering the backlight of the TV. If the backlight inverter is not working properly, it can result in a uniform blue screen.
LCD Panel: The LCD panel could be damaged or have developed a problem, causing the uniform blue screen.
Signal Cable: The cable connecting the main board to the T-Con board or the LCD panel could be damaged, causing a lack of signal and a blue screen.
It's best to consult with a professional repair technician or the manufacturer for further diagnosis and repair. They will be able to determine the exact cause of the issue and recommend the best course of action.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Sounds like back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board..
Hi Tong,
Any basis or reason to replace the two boards you replaced? Any voltage measurement? Further you have not mentioned the make and the model number.
Generally it is the inverter board that is found defective in 'no backlight' problems. If the power supply is producing necessary voltage and the main board is sending necessary command ie 'inverter on' and 'brightness control' to the inverter board and still it not producing the voltage required to drive the backlight, the inverter board is defective.
Good luck.
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/
Hi, maybe before replacing T-Con board it should be better to check voltages from power supply to the board, you could google for the service manual of your TV to have the right values of voltages and the signals you could check.
Samsung tv have issue with the board call the T-CON decoders board,will causes tv shutdown too.The T-CON decoders board sit in the middle at the bottom of the LCD screen panel.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish T-CON decoder board for the replacement.
It can be T-CON, MAIN, POWER supply, Inverter boards. First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board. if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having. If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on: Please see my basic troubleshooting guide here: http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps. Please post back what you find.
