SOURCE: canon IR 2200 error code E000002-0000
It's to do with the fixing unit (hot bit) left hand side. Make sure theres no paper **** any where near it. If so switch off then on.
If not it looks like there may be a fault with the fixing film or may just need the error resetting in service mode.
SOURCE: error code E000002-0000
Get in the service mode *28* and there under function, clear, err.
If not replace the fixing film unit
SOURCE: ERROR CODE E000002-0000
The error code means the fuser is not warming up or is not turning "ON" . Have you had a power surge recently? To reset it you have to go to service mode... To get in press these bottons on the control panel as follows > "*" then the numbers "2&8" at the same time then the "*"... The display will change then press "COPIER" Funcation > CLR (2nd collum) > ERR > then press "OK" in the bottom right corner. Then press the Reset key twice and turn the main power switch OFF on the right side and then back ON... If the code will not clear you have a bigger problem. Good Luck
SOURCE: CANON IR 3300 HAS ERROR CODE: E000002-0000
OK, but first try to clear the error under service mode, then replace fixing film assy, for EU 240V is FG6-6041.
To clear the error:
* 2 8 *
COPIER
FUNCTION
CLEAR
ERR
OK
Turn off and on ( main switch )
If this dont help - replace fixing film assy.
