Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
SOURCE: Necesito comprar un motor 2.0 GM Daewoo, MPI.
hola armando solo mandame el numero de vin del carro ke lo mas posible es ke se encuentre en la parte inferior del vidrio de enfrente del lado del chofer, y posiblemente asi te pueda ayudar,
tanvien tengo entendido ke aki en usa descontinuaron los daewood pero conosco algunos lugares donde tal vez lo puedas encontrar, como quiera ke sea mandame el vin y seguimos adelante, yo soy mexicano, buena suerte.
SOURCE: Informacion
por favor necesito codificar control remoto modelo rcr412si1612p para el televisor rca f27242gy
SOURCE: Drivers for emachines t 3958
hola...
intente esta página
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T3958
Robert
Please rate the solution
SOURCE: tiempo de encendido
Fabrizio:
Normalmente los modelos modernos Nissan no requieren ningún ajuste porque la escala es controlada por la computadora. Aun así, debe haber una etiqueta en el compartimiento del motor que indica todos los datos que busca.
SOURCE: MANUAL OF MOTHER SYNTAX Olevia Sv 266 M
go to syntax web site download driver and manual jim
