Hello Cathy, comment on the model of your TV Sansui and the brand and model of the remote control, for which you are needing the code, to try to find the best possible solution
I await your comment
Greetings Franco Dosil
Hola Cathy, comenta el modelo de tu TV Sansui y la marca y modelo del control remoto, por la cual estas necesitando el codigo, para tratar de encontrar la mejor solucion posible
Espero tu comentario
Saludos Franco Dosil
You need cable called RCA. What goes out of one unit goes in to another. Get the owner manual and read it. It will show you how to connect the wires to the components.
Connect the RCA jack to to tuner input in back. CD player to the aux in back.
You can connect the CD player to the amplifier using a standard set of RCA cables (left and right channel / red & white connectors). Connect the CD output to an input on the amplifier (usually one designated for CD or possibly "Aux") Then select this input source in order on the Amplifier.
There would be no reason to connect the CD player to a Tuner. Not even sure a tuner whould have any inputs in order to connect a CD player.
the above mentioned make and model # unit is a tuner, not a reciever, as a tuner, it's only function is to recieve radio signals, there is no internal amp, no selector switch for other components.
Try calling the customer service number on the back of your Sansui tv. If you ask them, they can probably email a copy of the manual.
I hope this is helpful.
Bobya.
SCANNED MANUAL ADDED
