Had this problem with my DC 23. It turned out to be a problem with power getting to the head. In the part of the hose that swivels, there are contacts inside that become loose. All I did was take that connection apart, bend the metal connectors so they will have a tighter fit and put it back together. I have had to do it twice since the first time I had the issue, but you can always replace the hose.
I have a Dyson DC 23 with the powerhead not turning on I tested the micro switches for continuity I've checked the hose the only thing I can figure is when I check continuity on the three wires on the hose the middle one gives continuity the left one and the middle one is a common ground and then the left one gives continuity to the left one but the right and middle somehow I have crossed paths? Is this possible
It may be an electrical problem getting power to the power head. You will have to figure out why it is not getting power
