I have had no problems until recently...but now when try to log on to yahoo email ...or acess a web site..it tell me internet explorer cannot acess the page . or web site ..please fix trhis.
Does this occur with all sites? How are you connecting to the internet (broadband, wireless, modem)? If you go to Start>Run, type cmd and hit return and then type ipconfig /all in the command window is an IP address assigned to an adapter? If not, it will start 169.*.*.*. If you do have an IP address are you able to ping addresses (open command prompt as above and type ping 212.42.175.205 then when that has finished type ping www.google.co.uk)? If you can get a ping response by IP address but not by FQDN (www.google.co.uk in this case) then the issue is with your DNS.Does this occur with all sites? How are you connecting to the internet (broadband, wireless, modem)? If you go to Start>Run, type cmd and hit return and then type ipconfig /all in the command window is an IP address assigned to an adapter? If not, it will start 169.*.*.*. If you do have an IP address are you able to ping addresses (open command prompt as above and type ping 212.42.175.205 then when that has finished type ping www.google.co.uk)? If you can get a ping response by IP address but not by FQDN (www.google.co.uk in this case) then the issue is with your DNS.
You can't post conmments that contain an email address.
Open
internet explorer Open Tools Tab Then click on Interbet optiobs Press delete cookies and wait then after a while press Delete Files and wait then press clear history.
Go to file menu locate work off line if it is checked pls, uncheck it.
Again go to Tools press Inter net options in Address type: http://www.yahoo.com/ and press use default.
If Your problem is solved donot forget to Rate it.
Thanks.
I got the answer from another web site. I tried it and it solved the problem.
Click tools in your yahoo home page >then select "Internet options" > click on "security" tab > click on "Restricted Sites" > , type in the following two sites.
Are you sure you are connected to the internet? If so you need to check the internet connection settings. You can also call your Internet service provider, and tell them your problem, they'll send their man and fix it for you. If you are connected and the ping is successful, there might be some other problem, first try with another browser, suppose if you are using Internet Explorer, try firefox. Run full system virus scan using an updated antivirus. There are lot more but please follow the above steps before you proceed forward. Good luck, let me know the result.
It's good that you have narrowed down the problem to when your laptop is at your work. I have two suggestions for narrowing it down further, (1) tell us exactly what error you get from Firefox when you try to access yahoo sites from your work (2) try a ping before and after you have a problem getting to yahoo sites. (You might want to try this a few times to see if it is consistent.)
If ping says 0% loss before and after you have a problem accessing Yahoo at work, then that suggests the problem is NOT with your wireless router (unless it is doing filtering). Instead, it would be more likely an issue with filtering/blocking/firewall or web cache/proxy. It might even be a deliberate decision by your work-place to block access to Yahoo for employees.
Check the privacy settings on your Internet Explorer Click Tools => Internet Options => Security => Restricted Sites and check if Yahoo is under the Blocked website list. If not, try downloading other browsers like Mozilla Firefox and try checking your email.
yahoo is currently experiencing browser issues...try logging in through ur internet explorer...if that doesnt work check ur connections...if that doesnt work call ur provider
Clear your internet cache in Internet Explorer:
1.Open Internet Explorer
2.At the top of the screen, click on Tools.
3.In the Tools menu, click on Internet Options...
4.If you do not see the tools menu hold down the alt and t key on the keyboard.
5.In the Internet Options window, find the Temporary Internet Files section. Click on Delete.
Delete Browsing History window will appear. Click on the Delete Files... button.
A verification screen will then come up. Click Yes to delete.
6. When this is finished, you can click Close and then OK on the Internet Options window and then you can try doing your yahoo and monster.com
Close all internet explorer windows and Click on Start and then click on Control panel. Look out for INTERNET OPTIONS.
double click on it and click on Advance Tab. Look out for Restore Defaults and Reset Button. Click on both button if you have both buttons or either click on restore defaults only.
Click on apply and than click on OK.
Open up internet explorer and try Yahoo mail. See if this do anything good to you.
