SOURCE: Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
SOURCE: Blank Screen, Flashing orange power light...
1st Idea - Let's take a look under the cover. I'm not sure how tech savvy you are, but I'm sure you're pretty good if you have a soldering iron. Once inside locate the power supply section. See if you see any blown capacitors on it or any other boards. One obvious way is to see if they are bad is if they have bulging up tops. There could be some weak or bad ones that aren't popped up, but let's start from there. If there are any bad caps, they are dirt cheap price wise at an electronics shop. Keep me posted and let em know what you find. - Scotty
SOURCE: POWER BUTTON IS BLINKING ORANGE
You may have a firmware or hardware problem, You may have to take it to a local PC repair store or contact the make of your computer
SOURCE: My acer aspire won't power up
Try to connect your PC with the battery on the power outlet if it lights and charge normally. If the lights still orange, try to open the hard disk case and pull it out then try to put it in place again. If still doesn't go, try the memory card and clean it.
But I suspect that the battery has been overly charged. Try to look for another battery of the same model if it works with another and new battery.
Thanks
SOURCE: power button if flashing orange and nothing else works
It's likely that your power supply has started to go out. There are several different leads with varying voltages & amps. If your computer is getting enough power to make a light flash yellow or orange then this often means that there is something wrong with one or more of the voltages from the power supply. Sometimes it means that something is wrong with your motherboard. Like: burned out capacitors, resistors, & etc.
