SOURCE: Red Light on Board
it is better to use the old power supply because it is compatible to your mother board
SOURCE: Sony Trinitron Power Surge 5 Blinks
once you have diagnosed the problem, the following link is to all parts for your tv stocked at partstore. they generally have better prices than the dealers and repair shops.
KV-36fs13 parts
you can try the dead-tv kit from fixyourowntv if you have some basic experience with soldering and circuit repair.
http://fixyourowntv.com/orderpage.php
Five blinks means, "IK (AKB)" (white balance). The probable causes listed by Sony are as follows:
1) Video OUT (IC561) is faulty (A board)
2) IC355 is faulty (A board)
3) Screen (G2) is improperly adjusted.
not sure what the 13 blinks are for.
hope this helps,
trin
SOURCE: 6 blinking red lights on my 50 inch phillips plasma.
If you see bad capicators, just replace the ones that appear to be bad. There are many different types of capicators on the power supply and there are different part number for each one. The good thing about capicators is they almost always list the ratings on the capacitor itself.
Check the Voltage rating (V) and the Farad ratings (F, usually μF), you can replace them with any one that has the same ratings. Make sure BOTH of them match the old ratings, you can purchase at just about any electronics store that carries electrical components such as RadioShack.
SOURCE: Working on a friend's LG
Hi syzonker
Before you replace the power supply , check for swollen(rounded top)capacitors.
Also check and replace C126 47mfds/50 volts
And C520 1000mfds/16 volts
good luck and let me know if you need further help
Testimonial: "Was getting somewhere with barbu51 when suddenly couldn't reply to him anymore. FixYa said one of his solutions was rated low - BUT NOT BY ME!"
SOURCE: The power/standby light blinks red 6 times
Six blinks - No Horizontal (H STOP), no raster, goes to
the blinking self-diagnosis function immediately. Check C515 & 516
and the jungle IC, IC206.
Not a DIY fix
Please rate my help++++Thanks for using FIXYA
Testimonial: "Thanks. That helps me in considering whether I want to get the TV fixed or buy a new one."
